Object Reference : Object View and Procedure Reference : Alpha
label
Display or change the label view of an alpha series, including the last modified date and display name (if any).
As a procedure, label changes the fields in the alpha series label.
alpha_name.label
alpha_name.label(options) text
To modify the label, you should specify one of the following options along with optional text. If there is no text provided, the specified field will be cleared:
c
Clears all text fields in the label.
d
Sets the description field to text.
s
Sets the source field to text.
u
Sets the units field to text.
r
Appends text to the remarks field as an additional line.
p
Print the label view.
The following lines replace the remarks field of ALPHA1 with “Data from CPS 1988 March File”:
alpha1.label(r)
alpha1.label(r) Data from CPS 1988 March File
To append additional remarks to ALPHA1, and then to print the label view:
alpha1.label(r) Hourly notes
alpha1.label(p)
See “Labeling Objects” for a discussion of labels.
See also Alpha::displayname.
