wgt=name (optional) | Name of series containing weights. |
wgtmethod=arg (default = “sstdev”) | Weighting method (when weights are specified using “weight=”): frequency (“freq”), inverse of variances (“var”), inverse of standard deviation (“stdev”), scaled inverse of variances (“svar”), scaled inverse of standard deviations (“sstdev”). |
pairwise | Compute using pairwise deletion of observations with missing cases (pairwise samples). |
out=name | Basename for saving output. All results will be saved in Sym matrices named using the string “CORR”, appended to the basename (e.g., the correlation specified by “out=my” is saved in the Sym matrix “MYCORR”). |
p | Print the result. |
Pearson correlation matrix for the three series HEIGHT, WEIGHT, and AGE.
