Scaled difference in the estimated betas for influence statistics.
DFBETAS are the scaled difference in the estimated betas between the original equation and an equation estimated without that observation.
equation_name.infbetas(options) [base_name]
where base_name is an optional naming suffix used to store the DFBETAS into the workfile.
t  | Show a table of the statistics (the default is to display a graph view of the specified statistics).   |
rows = key  | The number of observations/rows to display in the table, where key can be either “50”, “100” (default), “150”, or “200”.  |
g=arg  | arg is the name of an object in which the graph output will be saved.  |
prompt  | Force the dialog to appear from within a program.  |
equation eq1.ls y c x z
eq1.infbetas
displays a graph of the DFBETAS corresponding to the coefficients for C, X, and Z.
eq1.infbetas(t) out
will display a table showing the first 150 rows of DFBETAs in table form and saves the results in the series COUT, XOUT and ZOUT.
