lambdaest
Display the table showing various values associated with estimation along the lambda path.
This view is only available for equations estimated with elastic net, ridge regression, Lasso, and variable selection using Lasso.
Display a table showing the number of non-zero coefficients, estimation objective, sums-of-squared residuals penalty, and where applicable, the L1-norm and the L2-norm penalty portions of the objective associated with each lambda in the path.
The row displaying the model selected optimal lambda will be highlighted.
eq_name.lambdaest(options)
p
Print output.
Consider the estimated elastic net equation
equation my_eq.enet(xtrans=none, lambdaratio=.0001, cvseed=513255899) lpsa c lcavol_s lweight_s age_s lbph_s svi_s lcp_s gleason_s pgg45_s
Then the command
my_eq.lambdaest
displays the table showing various estimation statistics associated with each lambda in the path.
For further discussion, see “Elastic Net and Lasso”.
See also Equation::coefpath, Equation::lambdafit, and Equation::lambdapath.
The data underlying this table are available via the data member @lambdaest.
