Make a model from an equation object.
equation_name.makemodel(name) assign_statement
If you provide a name for the model in parentheses after the keyword, EViews will create the named model in the workfile. If you do not provide a name, EViews will open an untitled model window if the command is executed from the command line.
equation eq3.ls 1 4 m1 gdp tb3
eq3.makemodel(eqmod) @prefix s_
estimates an equation and makes a model named EQMOD from the estimated equation object. EQMOD includes an assignment statement “ASSIGN @PREFIX S_”. Use the command “show eqmod” or “eqmod.spec” to open the EQMOD window.
See
“Models” for a discussion of specifying and solving models in EViews. See also
solve.
