Object Reference : Object View and Procedure Reference : Factor
eigen
Display table or graph of eigenvalues of observed, scaled observed, or reduced covariance matrix.
factor_name.eigen(options)
By default, eigen will display a table of eigenvalues for the specified source matrix. You may add the option keywords “eigvec” and “matrix” to include additional output.
To display a graph of the results, you should some combination of the “scree”, “diff” and “cproport” option keywords.
source=arg (default= “observed”)
Source matrix to be analyzed: “observed” (observed covariance matrix), “scaled” (scaled observed matrix), “reducedinit” (reduced using initial uniquenesses), “reduced” (reduced using final uniquenesses).
eigvec
Add the eigenvectors to the table of eigenvalue results. May be combined with the “matrix” keyword.
matrix
Display the source matrix along with the table of eigenvalue results. May be combined with the “eigvec” keyword.
scree
Display eigenvalue graph of the ordered eigenvalues (Scree plot). May be combined with the “diff” and “cproport” keywords.
diff
Display graph of the difference in successive eigenvalues. May be combined with the “scree” and “cproport” keywords.
cproport
Display graph of the cumulative proportion of total variance associated with each eigenvalue/eigenvector. May be combined with the “scree” and “diff” keywords.
prompt
p
Print results.
f1.eigen(source=observed, scree)
displays the scree plot based on the observed covariance matrix.
f1.eigen(source=reducedinit, eigvec, matrix)
displays a table of eigenvalues and corresponding eigenvectors for the reduced covariance matrix (using the initial uniquenesses). The table also shows the reduced covariance matrix.
f1.eigen(source=reducedinit, scree, cproport, diff)
shows the scree, cumulative proportion, and eigenvalue difference graphs based on the reduced initial covariance.
See “Eigenvalues”.
