Cumulative quantiles of a series.
Increasing samples calculation of the quantile value where approximately 100*q percent of the data is less than or equal to the value,
Syntax: @cumquantile(x, q, [s])
x: series
q: number, series
s: (optional) sample string or object
Return: series
• The quantile value
q must satisfy
• The cumulative quantiles are computed using the Rankit-Cleveland definition of the empirical distribution function: for observation
To compute the cumulative quantile for observation
find
, the smallest rank such that:
where the order statistics
represent data from the beginning of the workfile or sample
s, up to the current observation (
), ordered from low to high. For purposes of computing
, tied ranks are assumed to take the last tied value.
Then the quantile is computed as
where the interpolating constant is
for
the smallest integer where
. In the leading case where there are no tied
values,
This function is panel aware.
show @cumquantile(@nrnd, 0.975)
generates a linked series that converges in probability to 1.95996... (the 97.5th percentile of the standard normal distribution).
For the backward variant of this function, see
@cumbquantile.
