Kurtosis.
Computes the kurtosis of the elements of x.
Syntax: @kurt(x[, s])
x: numeric object
s: (optional) sample string or object when x is a series and assigning to a series
Return: number
The kurtosis is calculated as
where
is the sample mean, and
is an estimator for the standard deviation that is based on the biased estimator for the variance
The kurtosis of the normal distribution is 3. If the kurtosis exceeds 3, the distribution is peaked (leptokurtic) relative to the normal; if the kurtosis is less than 3, the distribution is flat (platykurtic) relative to the normal.
If x = @nrnd, then
= @kurt(x)
returns a value close to 3 in large samples (since the normal distribution has a kurtosis of 3).
See also
@mean,
@var, and
@skew.
