Home
Products & Pricing
User Community
Learning Resources
About EViews
Buy Now
Panel Progress
EViews 14 Help Topics
Registration
Help Reference
What’s New in EViews 14
Getting Started
Installing EViews
Installing the Program
Registering EViews
What is Registration?
How Do I Register?
Auto Registration
Manual Registration
Contact Information
Frequently Asked Questions about Registration
Updating Your Copy of EViews
Where to Go For Help
Online Help
The Help System
The EViews Manuals (PDF Files)
Tutorials
The EViews Forum
New Features in EViews 14
Data Sources and File Formats
Seasonal Adjustment
Filtering and Smoothing
Expanded Functions
Estimation and Analysis
Forecasting
Testing and Diagnostics
Matrix Statistical Tools
Data Handling
Statistics Canada (StatCan SDMX) Database Connectivity
NOAA (National Oceanic And Atmospheric Administration)
Find Data By Location
Locations From Stations
Statistical Data and Metadata eXchange (SDMX) Databases
Selecting a Database
Selecting Series
JDemetra+ Seasonal Adjustment
Example
Boosted Hodrick-Prescott Filter
Utility Functions
Sample Index Functions
Current Sample Index (@pagesmplidx)
Observations Index (@pageidx)
Boolean Indicators (@pageinidx)
Matrix Utility Functions
String and Date Vector Functions
Econometrics and Statistics
MIDAS GARCH
Quantile ARDL Estimation
Enhanced Elastic Net and Lasso
Lasso Variable Selection
Lasso Options
Expanded ARDL HAC Standard Errors
Facebook Prophet Forecasting
Background
Using Prophet in EViews
Example
Series-based Outlier Detection
Equation-based Outlier Detection
Break Testing and Change Point Detection
Trend Testing
Explosive Bubble Testing
Impulse Response Analysis
Impulse Response via Local Projection
SVAR Impulse Response and Variance Decomposition CIs
BTVCVAR Fixed Horizon Impulse-Responses
New Matrix Object Views and Procs
New Matrix Views and Procs
Models
Models Containing Future Endogenous Values
Gauss-Seidel
E-Newton and E-QNewton
Forward Solution Options
Command Language
Updated Object List
Updated Function List
EViews Compatibility Notes
Workfile Compatibility
User’s Guide
EViews Fundamentals
Introduction
What is EViews?
The EViews Window
Pane and Tab User Interface
Custom Edit Fields in EViews
Breaking or Canceling Operations in EViews
Closing EViews
EViews Updates
A Demonstration
Getting Data into EViews
Examining the Data
Estimating a Regression Model
Specification and Hypothesis Tests
Modifying the Equation
Forecasting from an Estimated Equation
Additional Testing
Workfile Basics
What is a Workfile?
Creating a Workfile
The Workfile Window
Saving a Workfile
Loading a Workfile
Multi-page Workfiles
Comparing Workfiles
Addendum
Object Basics
What is an Object?
Basic Object Operations
The Object Window
Working with Objects
Basic Data Handling
Data Objects
Samples
Sample Objects
Importing Data
Exporting Data
Reading EViews Data using Other Applications
Frequency Conversion
Value-Based Text and Fill Coloring
References
Working with Data
Numeric Expressions
Series
Auto-series
Groups
Scalars
Working with Data (Advanced)
Auto-Updating Series
Alpha Series
Date Series
Value Maps
Series Links
Basic Link Concepts
Creating a Link
Working with Links
Advanced Workfiles
Structuring a Workfile
Resizing a Workfile
Appending to a Workfile
Contracting a Workfile
Copying from a Workfile
Reshaping a Workfile
Sorting a Workfile
Exporting from a Workfile
References
EViews Databases
Database Overview
Database Basics
Working with Objects in Databases
Database Auto-Series
The Database Registry
Querying the Database
Object Aliases and Illegal Names
Maintaining the Database
Foreign Format Databases
Basic Data Analysis
Series
Series Views Overview
Spreadsheet
Graph
Descriptive Statistics & Tests
One-Way Tabulation
Duplicates Analysis
Forecast Evaluation
Outlier Detection
Correlogram
Long-run Variance
Change Point Tests
Trend Tests
Explosive Bubble Tests
Unit Root Test
Breakpoint Unit Root Test
Seasonal Unit Root Test
Panel Unit Root Test
Variance Ratio Test
BDS Independence Test
Label
Properties
Series Adjust
Series Procs Overview
Generate by Equation
Generate by Classification
Resample
Interpolate
Seasonal Adjustment
Automatic Forecasting
Forecast Averaging
Exponential Smoothing
Frequency (Band-Pass) Filter
Whiten Data
Distribution Plot Data
Testing for Bubbles
Wavelet Objects
References
Groups
Group Views Overview
Group Members
Spreadsheet
Dated Data Table
Graph
Covariance Analysis
N-Way Tabulation
Tests of Equality
Principal Components
Correlograms
Cross Correlations and Correlograms
Long-run Covariance
Unit Root Tests
Cointegration Test
Granger Causality
Label
Group Procedures Overview
References
Geomaps
Overview
Creating and Configuring a Geomap
Navigating the Geomap Display
Graphing Data
Quick Start
Graphing a Series
Graphing Multiple Series (Groups)
The Graph Sample
Graph Pan and Zoom
Multi-graph Slideshow
Animated Graphs
Basic Customization
Graph Types
References
Categorical Graphs
Illustrative Examples
Specifying Factors
Customizing Output
Graph Objects
Creating Graph Objects
Combining Graphs
Customizing Graphs
Modifying Multiple Graphs
Printing Graphs
Saving Graphs to a File
Graph Commands
Table and Text Objects
Table Objects
Text Objects
Spool Objects
Creating a Spool
Managing the Spool
Customizing the Spool
Editing Objects in a Spool
Printing a Spool
Saving a Spool
Extending EViews
Create Your Own Estimator
Add Menu Items and Object Classes
Connect with External Applications
Object Linking and Embedding (OLE)
Embedding vs. Linking
Using OLE
Opening Documents with Linked Objects
Basic Single Equation Analysis
Basic Regression Analysis
Equation Objects
Specifying an Equation in EViews
Estimating an Equation in EViews
Equation Output
Working with Equations
Estimation Problems
References
Additional Regression Tools
Special Equation Expressions
Robust Standard Errors
Weighted Least Squares
Nonlinear Least Squares
Indicator Saturation
References
Regression Variable Selection
Background
Variable Selection Estimation in EViews
Working with an Estimated Equation
Example
References
Instrumental Variables and GMM
Background
Two-stage Least Squares
Nonlinear Two-stage Least Squares
Limited Information Maximum Likelihood and K-Class Estimation
Generalized Method of Moments
IV Diagnostics and Tests
References
Time Series Regression
Background
Testing for Serial Correlation
Estimating ARIMA and ARFIMA Models in EViews
Estimation Output
Equation Diagnostics
Additional Topics
Estimation Method Details
References
Forecasting from an Equation
Forecasting from Equations in EViews
An Illustration
Forecast Basics
Forecasts with Lagged Dependent Variables
Forecasting with ARMA Errors
Forecasting from Equations with Expressions
Forecasting with Nonlinear and PDL Specifications
References
Specification and Diagnostic Tests
Background
Outlier Detection
Coefficient Diagnostics
Residual Diagnostics
Stability Diagnostics
Applications
References
Advanced Single Equation Analysis
ARCH and GARCH Estimation
Basic ARCH Specifications
Estimating ARCH Models in EViews
Working with ARCH Models
Additional ARCH Models
References
Cointegrating Regression
Background
Estimating a Cointegrating Regression
Testing for Cointegration
Working with an Equation
References
ARDL and Quantile ARDL
Background
Estimating ARDL Models in EViews
Views and Procs of ARDL
References
Midas Regression
Background
MIDAS Estimation in EViews
An Example
References
Discrete and Limited Dependent Variable Models
Binary Dependent Variable Models
Ordered Dependent Variable Models
Censored Regression Models
Truncated Regression Models
Heckman Selection Model
Count Models
Technical Notes
References
Generalized Linear Models
Overview
How to Estimate a GLM in EViews
Working with a GLM Equation
Technical Details
References
Robust Least Squares
Background
Estimating Robust Regression in EViews
An Illustration
References
Least Squares with Breakpoints
Background
Estimating Least Squares with Breakpoints in EViews
Working with Breakpoint Equations
Example
References
Discrete Threshold Regression
Background
Threshold Estimation in EViews
Working with Threshold Equations
References
Smooth Transition Regression
Background
Estimating a Smooth Transition Regression in EViews
Working with Smooth Threshold Equations
Example
References
Background
How to Estimate an Elastic Net Specification in EViews
Working with Elastic Net Equations
Cross-validation Settings
References
Functional Coefficient Regression
Background
Estimating Functional Coefficients Models in EViews
Post-Estimation Views and Procs
References
Switching Regression
Background
Estimating Switching Regressions in EViews
Estimation Output
Switching Views
Switching VAR Procs
References
Quantile Regression
Estimating Quantile Regression in EViews
Views and Procedures
Background
References
The Log Likelihood (LogL) Object
Overview
Specification
Estimation
LogL Views
LogL Procs
LogL Specific Views and Procedures
Troubleshooting
Limitations
References
Advanced Univariate Analysis
Univariate Time Series Analysis
Change Point Tests
Trend Tests
Unit Root Testing
Unit Root Tests with a Breakpoint
Seasonal Unit Root Testing
Cross-sectionally Independent Panel Unit Root Testing
Cross-sectionally Dependent Panel Unit Root Tests
Variance Ratio Test
Wavelet Analysis
References
Multiple Equation Analysis
System Estimation
Background
System Estimation Methods
How to Create and Specify a System
Working With Systems
Technical Discussion
References
Vector Autoregression (VAR) Models
Unrestricted VARs
VARs With Linear Constraints
Views and Procs of a VAR
Data Members of a VAR
Structural (Identified) VARs
Data Members of a SVAR
References
Vector Error Correction Models (VECMs)
Background
Estimating VEC Models in EViews
VEC Estimation Output
Views and Procs of a VEC
VEC Data Members
References
Impulse Response Functions
Impulse Response Confidence Intervals
Impulse Responses Analysis in EViews
References
Bayesian VAR Models
Estimating a Bayesian VAR in EViews
Post-Estimation Procedures
Technical Background
References
Bayesian Time-varying Coefficients VAR Models
Background
Estimating BTVCVAR in EViews
Working with a BTCVAR
Implementation Details
Example
References
Mixed Frequency VAR
Estimating a Mixed Frequency VAR in EViews
An Example
References
Switching VAR
Background
Specifying a Switching VAR in EViews
Post-Estimation Results
References
State Space Models and the Kalman Filter
Background
Specifying a State Space Model in EViews
Working with the State Space
Converting from Version 3 Sspace
References
Models
Overview
An Example Model
Building a Model
Working with the Model Structure
Specifying Scenarios
Using Add Factors
Locking the Model
Solving the Model
Working with the Model Data
Comparing Solution Data
References
Panel and Pooled Data
Pooled Time Series, Cross-Section Data
The Pool Workfile
The Pool Object
Pooled Data
Setting up a Pool Workfile
Working with Pooled Data
Pooled Estimation
References
Working with Panel Data
Structuring a Panel Workfile
Panel Workfile Display
Panel Workfile Information
Panel Data Analysis
References
Panel Estimation
Estimating a Panel Equation
Panel Estimation Examples
Panel Equation Testing
Estimation Background
References
Difference-in-Difference Estimation
Background
Estimating DiD in EViews
References
Panel Cointegration Estimation
Background
Estimating Panel Cointegration in EViews
Working With a Panel Cointegrating Equation
Technical Details
References
Panel Statistics
Time Series Graphs
By-Statistics
Panel Covariances
Panel Principal Components
Panel Causality Testing
Panel Long-run Variances
Panel Cointegration Testing
Panel Cross-section Dependence Test
Panel Resampling
Panel Stacked Analysis
References
Advanced Multivariate Analysis
Johansen Cointegration Test
Single-Equation Cointegration Tests
References
Factor Analysis
Creating a Factor Object
Rotating Factors
Estimating Scores
Factor Views
Factor Procedures
Factor Data Members
An Example
Background
References
Global Options
The Options Menu
General Options
Graphics Defaults
Database Registry
Cloud Management
EViews Auto-Update from Web
Print Setup
Global Options Export and Import
Enhanced Spreadsheet Editing
Array Expressions
Operators
Values
Interpolation
Estimation and Solution Options
Setting Estimation Options
Optimization Method
Iteration and Convergence
Starting Coefficient Values
Derivative Computation
Optimization Algorithms
Second Derivative Methods
First Derivative Methods
Choosing the step size
Derivative free methods
Nonlinear Equation Solution Methods
Gauss-Seidel
Newton's Method
Broyden's Method
References
Gradients and Derivatives
Gradients
Gradient Summary
Gradient Table and Graph
Gradient Series
Application to LM Tests
Gradient Availability
Derivatives
Derivative Description
Derivative Table and Graph
Derivative Series
References
Information Criteria
Definitions
Using Information Criteria as a Guide to Model Selection
References
Long-run Covariance Estimation
Nonparametric Kernel
Parametric VARHAC
Prewhitened Kernel
Kernel Function Properties
References
Command Reference
Object and Command Basics
Command Capture
Using Commands
Interactive Use
Batch Program Use
Object Declaration and Initialization
Object Declaration
Object Assignment
Object Modification
More on Object Declaration
Object Commands
Action Commands
View and Procedure Commands
Object Data Members
Interactive Commands
Auxiliary Commands
Managing Workfiles and Databases
Managing Objects
Renaming Objects
Deleting Objects
Saving Objects
Fetch Objects
Working with Graphs
Creating a Graph
Displaying graphs using commands
Displaying graphs as object views
Creating graph objects from object views
Creating named graph objects
Creating unnamed graph objects
Changing Graph Types
Customizing a Graph
Line characteristics
Use of color with lines and filled areas
Filled area characteristics
Using preset lines and fills
Scaling and axes
Customizing the graph frame
Labeling data values
Outlining and spacing filled areas
Modifying the Legend
Adding text to the graph
Adding lines and shading
Using graphs as templates
Arranging multiple graphs
Modifying Boxplots
Labeling Graphs
Printing Graphs
Exporting Graphs to Files
Graph Summary
Working with Tables and Spreadsheets
Creating a Table
Creating Tables from an Object View
Declaring Tables
Assigning Table Values
Assigning Strings
Assigning Numbers
Assignment with Formatting
Customizing Tables
Column Width and Row Height
Cell Formatting
Conditional Table Cells
Labeling Tables
Printing Tables
Exporting Tables to Files
Customizing Spreadsheet Views
Table Summary
Working with Spools
Creating a Spool
Working with a Spool
Adding Objects
Naming Objects
Object Displaynames
Object Comments
Removing Objects
Extracting Objects
Customizing the Appearance
Printing the Spool
Spool Summary
Strings and Dates
Strings
String Operators
String Lists
String Functions
Using Strings in EViews
Dates
Date Strings
Date Numbers
Date Formats
Translating between Date Strings and Date Numbers
Translating Ordinary Numbers into Date Numbers
Manipulating Date Numbers
Extracting Information from Date Numbers
Special Date Functions
Free-format Conversion Formats
Free-format Conversion Details
Time Zones
EViews Programming
Program Basics
What is a Program?
Creating a Program
Program Formatting
Saving a Program
Saving the Command Window
Encrypting a Program
Opening a Program
Executing a Program
Stopping a Program
Running Part of a Program
Program Debugging
Program Dependency Logging
Simple Programs
Program Variables
Control Variables
String Variables
Replacement Variables
Program Modes
Program Message Logging
Program Arguments
Program Options
Control of Execution
IF Statements
The FOR Loop
The WHILE Loop
Execution Errors
Stopping Programs
Exiting Loops
Multiple Program Files
Subroutines
Defining Subroutines
Subroutine with Arguments
Calling Subroutines
Subroutine Placement
Global and Local Variables
Global Subroutines
Local Subroutines
Local Samples
User-Defined Dialogs
@uiprompt
@uiedit
@uilist
@uimlist
@uiradio
@uidialog
@uifiledlg
Example Program
Version 4 Compatibility Notes
String vs. Replacement Variables
String Variables in String Expressions
Case-Sensitive String Comparison
Comparisons Involving NAs/Missing Values
Version 4 Compatibility Mode
References
External Connectivity
Reading EViews Data
The OLEDB Driver
The Excel Add-in
EViews Database Objects (EDO) Library
EViews COM Automation Server
EViews COM Automation Client Support (MATLAB, R, Python)
Using MATLAB®
Using R
Using Python
EViews Database Extension Interface
Jupyter Notebook Support
Using the EViews Jupyter Kernel
Add-ins
What is an Add-in?
Getting Started with Add-ins
Using Add-ins
Add-ins Examples
Summarize Equation Results
U.S. Recession Graph Shading
Managing Add-ins
Registered Add-ins
Default Add-ins Directory
Creating an Add-in
Registering an Add-in
Add-ins Design Issues
Creating an Add-in Package
Add-ins Design Support
Add-ins Registration Command
The Active Object Keyword
“_this” Keyword
Custom Object Output
User Objects
What is a User Object?
Unregistered User Objects
Registered User Objects
Downloading a Registered User Object
Working with Registered User Objects
Simple Container Object (ResStore)
Rolling Regression Estimation Object (Roll)
Managing User Object Classes
Default User Objects Directory
Defining a Registered User Object Class
Creating an Object Definition File
Registering a User Object Class
Creating a User Object Package
User Object Programming Support
Declaration
Registration
View and Procs
Data Members
User-Defined Optimization
Defining the Objective and Controls
The Optimize Command
Specifying the Method and Objective
Identifying the Control
Starting Values
Specifying Gradients
Calculating the Hessian
Numeric Derivatives
Advanced Optimization Options
Status Functions
Error Handling
Technical Details
Hessian Approximation
Step Method
Scaling
Optimization Termination
References
Matrix Language
Declaring Matrix Objects
Assigning Matrix Values
Element assignment
Fill assignment
Matrix assignment
Copying Data Between Objects
Copying Data From Matrix Objects
Extracting Part of a Matrix Objects
Assigning to Part of a Matrix Objects
Copying Data Between Matrices and Series/Groups
Matrix Expressions
Matrix Operators
Matrix Commands and Functions
Utility Commands and Functions
Element Functions
Matrix Algebra Functions
Descriptive Statistics Functions
Functions versus Commands
NA Handling
Matrix Graph and Statistics Views
Matrix Input and Output
Matrix Operations versus Loop Operations
Workfile Functions
Basic Workfile Information
Workfile Sample Information
Dated Workfile Information
Basic Date Functions
Trend Functions
Event Functions
Indicator Functions
Panel Workfile Functions
Panel Identifier Functions
Panel Trend Functions
Special Expression Reference
Special Expression Summary
ar
d
@expand
ma
na
pdl
sar
sma
String and Date Summary
String Function Summary
Date Function Summary
Matrix Language Summary
Matrix Command Summary
Matrix Function Summary
Programming Language Summary
Program Statements
Support Commands
Support Functions
Workfile Utility Functions
Dialog Display Functions
Programming Language Entries
call
else
endif
endsub
exitloop
for
if
include
poff
pon
return
sleep
step
stop
subroutine
then
to
wend
while
Command Reference
Commands
addin
adduo
arch
archtest
ardl
auto
binary
breakls
cause
ccopy
cd
censored
cfetch
chdir
chow
clabel
clearerrs
close
coint
cointreg
colplace
commandcap
copy
cor
count
cov
create
cross
data
db
dbcopy
dbcreate
dbdelete
dbopen
dbpack
dbrebuild
dbrename
delete
deleteaddin
did
do
driconvert
enet
deleteaddin
exec
exit
expand
facbreak
factest
fetch
fit
forecast
freeze
frml
funcoef
genr
glm
gmm
Basic GMM Options
Estimation Weighting Matrix Options
Covariance Options
heckit
hconvert
help
hfetch
hist
hlabel
hpf
import
importattr
importmat
Excel Files
HTML Files
Text and Binary Files
importtbl
Excel Files
HTML Files
liml
load
logclear
logclose
logeval
logit
logmode
logmsg
logsave
ls
matplace
midas
mtos
nrnd
open
optimize
optsave
optset
ordered
output
pageappend
pagecontract
pagecopy
pagecreate
pagedelete
pageload
pagerefresh
pagerename
pagesave
Excel Files
HTML Files
Text and Binary and Other Files
pageselect
pagesort
pagestack
pagestruct
pageunlink
pageunstack
param
plot
preview
print
probit
program
qreg
range
read
rename
reset
rmvnorm
rnd
rndint
rndseed
robustls
rowplace
run
save
saveprgini
seas
setcell
setcolwidth
seterr
seterrcount
setmaxerrs
setline
shell
show
smooth
smpl
solve
sort
spawn
stats
statusline
stom
stomna
store
switchreg
tabplace
testadd
testdrop
threshold
tic
toc
tsls
ttom
unlink
uroot
varest
varsel
Penalty Options
Cross Validation Options
Random Number Options
Other Options
wfclose
wfcompare
wfcreate
wfdetails
wfdir
wffilter
wfopen
Aremos Example
GiveWin/PcGive Example
Rats Examples
TSP Portable Example
Excel and Lotus Files
HTML Files
ODBC or Microsoft Access
Other Dataset Types
wforder
wfrefresh
wfsave
Excel Files
wfselect
wfsnapshot
wfstats
wfunlink
wfuse
workfile
write
xclose
xget
xlog
xoff
xon
xopen
xpackage
xput
xrun
Function Reference
Function Arguments
Function Summaries
Operators
Element Functions
Basic Statistics
Series Utility
Workfile Functions
Rolling (Moving) Statistics
Cumulative Statistics
By-Group Statistics
By-Row Statistics
Matrix Functions
Support Functions
Function Reference: A
@abs
abs
@acos
@addinspath
@addquotes
@after
@asc
@asin
@atan
@attrnames
@attrvals
Function Reference: B
@before
@beta
@betainc
@betaincder
@betaincinv
@betalog
@between
@binom
@binomlog
@bounds
@bridge
Function Reference: C
@cagr
@capplyranks
@cbeta
@cbinom
@cbvnorm
@cchisq
@ceil
@cellid
@cexp
@cextreme
@cfdist
@cfirst
@cgamma
@cged
@chisq
@cholesky
@chr
@cifirst
@cilast
@cimax
@cimin
@cintercept
@claplace
@clast
@clogistic
@cloglog
@clognorm
@cmax
@cmean
@cmedian
@cmin
@cnas
@cnegbin
@cnorm
@cobs
@colcumprod
@colcumsum
@coldemean
@coldetrend
@colpctiles
@colranks
@colsort
@colstdize
@colstdizep
@columnextract
@columns
@commute
@cond
@convert
@cor
@cos
@cov
@covp
@covs
@cpareto
@cpoisson
@cprod
@cquantile
@crossid
@cstdev
@cstdevp
@cstdevs
@csum
@csumsq
@ctdist
@ctrendcoef
@ctrmean
@cumbmax
@cumbmean
@cumbmedian
@cumbmin
@cumbnas
@cumbobs
@cumbprod
@cumbquantile
@cumbstdev
@cumbstdevp
@cumbstdevs
@cumbsum
@cumbsumsq
@cumbvar
@cumbvarp
@cumbvars
@cumdn
@cumdp
@cumdz
@cummax
@cummean
@cummedian
@cummin
@cumnas
@cumobs
@cumprod
@cumquantile
@cumstdev
@cumstdevp
@cumstdevs
@cumsum
@cumsumsq
@cumvar
@cumvarp
@cumvars
@cunif
@cvalcount
@cvar
@cvarp
@cvars
@cweib
Function Reference: D
d
@datapath
@date
@dateadd
@datediff
@dateceil
@datefloor
@datenext
@datepart
@datestr
@dateval
@day
@daycount
@dbeta
@dbinom
@dbname
@dbvnorm
@dchisq
@dcumdn
@dcumdp
@dcumdz
@demean
@demeanby
@det
@detrend
@dexp
@dextreme
@dfdist
@dgamma
@dged
@digamma
@diwish
@dlaplace
dlog
@dlogistic
@dlognorm
@dmvnorm
@dnegbin
@dnorm
@dpareto
@dpoisson
@dtdist
@dtoo
@dunif
@duplic
@duplicinv
@dupselem
@dupsid
@dupsobs
@during
@dweib
@dwish
Function Reference: E
@ebtw
@ediv
@eeq
@eeqna
@ege
@egt
@eigenvalues
@eigenvectors
@einv
@eisna
@ele
@elimin
@elt
@emax
@emin
@emult
@enddate
@eneq
@eneqna
@enisna
@env
@epow
@eqna
@equaloption
@erecode
@erf
@erfc
@errorcount
@event
@evpath
@exp
exp
@explode
@expm1
Function Reference: F
@fact
@factlog
@fdist
@fileexist
@fill
@filledmatrix
@filledrowvector
@filledsym
@filledvector
@first
@firstsby
@floor
@folderexist
@fracdiff
@fv
Function Reference: G
@gamma
@gammader
@gammainc
@gammaincder
@gammaincinv
@gammalog
@getmaindiagonal
@getnextname
@getthistype
@gmean
@grid
Function Reference: H
@hasoption
@hcat
@hmean
@holiday
@holidayset
@hour
@hourf
Function Reference: I
@identity
@ifirst
@iif
@ilast
@imax
@imaxes
@imin
@imins
@implode
@implodeu
@incr
@inlist
@inner
@insert
@instr
@intercept
@inv
@inverse
@isempty
@isna
@isobject
@ispanel
@isperiod
@issingular
@isvalidgroup
@isvalidname
Function Reference: J
Function Reference: K
@kronecker
@kurt
@kurtsby
Function Reference: L
@lag
@last
@lastsby
@lasterrnum
@lasterrstr
@left
@len
@length
@linepath
@loadprgini
@localt
@log
log
@log10
@log1mexp
@log1p
@log2pi
@logcnorm
@logit
@logx
@lower
@ltrim
@lu
Function Reference: M
@mae
@makedate
@makediagonal
@makevalidname
@mape
@mav
@mavc
@max
@maxerrcount
@maxes
@maxsby
@mcor
@mcov
@mcovp
@mcovs
@mean
@meansby
@median
@mediansby
@mid
@min
@minner
@mins
@minsby
@minute
@mkurt
@mmax
@mmedian
@mmin
@mnas
@mnrnd
@mobs
@mod
@month
@movav
@movavc
@movcor
@movcov
@movcovp
@movcovs
@movinner
@movkurt
@movmax
@movmedian
@movmin
@movskew
@movstdev
@movstdevp
@movstdevs
@movsum
@movsumsq
@movvar
@movvarp
@movvars
@mrnd
@mse
@mskew
@mstdev
@mstdevp
@mstdevs
@msum
@msumsq
@mvar
@mvarp
@mvars
Function Reference: N
@nan
@nas
@nasby
@neqna
@norm
@now
@nper
Function Reference: O
@obs
@obsby
@obsid
@obsrange
@obssmpl
@ones
@option
@otod
@otods
@outer
Function Reference: P
@pagecount
@pageexist
@pagefreq
@pageids
@pageidx
@pageinidx
@pagelist
@pagename
@pagerange
@pagesmpl
@pagesmplidx
@pc
@pca
@pccagr
@pch
@pcha
@pchy
@pctiles
@pcy
@periodtodate
@permute
@pi
@pinverse
@pmax
@pmin
@pmt
@pow
@pow1pm1
@powm1
@prod
@psi
@pv
Function Reference: Q
@qbeta
@qbinom
@qchisq
@qexp
@qextreme
@qfdist
@qform
@qgamma
@qged
@qlaplace
@qlogistic
@qlognorm
@qnegbin
@qnorm
@qpareto
@qpoisson
@qr
@qtdist
@quantile
@quantilesby
@quarter
@qunif
@qweib
Function Reference: R
@range
@rank
@ranks
@rapplyranks
@rate
@rbeta
@rbinom
@rchisq
@recode
@regress
@replace
@resample
@rexp
@rextreme
@rfdist
@rfirst
@rgamma
@rged
@rifirst
@right
@rilast
@rimax
@rimin
@rinstr
@riwish
@rlaplace
@rlast
@rlogistic
@rlognorm
@rmax
@rmean
@rmedian
@rmin
@rmse
@rmvnorm
@rnas
@rnegbin
@rnorm
@robs
@round
@rowextract
@rowranks
@rows
@rowsort
@rpareto
@rpoisson
@rprod
@rquantile
@rstdev
@rstdevp
@rstdevs
@rsum
@rsumsq
@rsweep
@rtdist
@rtrim
@runif
@runpath
@rvalcount
@rvar
@rvarp
@rvars
@rweib
@rwish
Function Reference: S
@scale
@seas
@second
@seq
@seqm
@sfill
@sign
@sin
@skew
@skewsby
@smape
@solvesystem
@sort
sqr
@sqrt
@stdev
@stdevp
@stdevpsby
@stdevs
@stdevsby
@stdevssby
@stdize
@stdizep
@str
@strdate
@stripcommas
@stripparens
@stripquotes
@strlen
@strnow
@subextract
@sum
@sumsby
@sumsq
@sumsqsby
@svd
@svdfull
@sweep
Function Reference: T
@tablenames
@tan
@tdist
@temppath
@theil
@time
@toc
@trace
@transpose
@trend
@trendbr
@trendc
@trendcoef
@trigamma
@trim
@trmean
@tz
@tzlist
@tzspec
Function Reference: U
@uidialog
@uiedit
@uifiledlg
@uilist
@uimlist
@uiprompt
@uiradio
@uniquevals
@unitvector
@unvec
@unvech
@upper
@utc
Function Reference: V
@val
@valcount
@var
@varp
@varpsby
@vars
@varsby
@varssby
@vcat
@vec
@vech
@vernum
@verstr
Function Reference: W
@wcount
@wcross
@wdelim
@wdir
@wdrop
@weekday
@wexpand
@wfattrnames
@wfattrvals
@wfind
@wfindnc
@wfname
@wfpath
@winsert
@winterleave
@wintersect
@wjoin
@wkeep
@wleft
@wlookup
@wmid
@wnotin
@word
@wordq
@wquery
@wread
@wreplace
@wrfind
@wrfindnc
@wright
@wsort
@wsplit
@wunion
@wunique
Function Reference: X
@xgetstr
@xgetnum
@xputnames
@xtype
@xverstr
@xvernum
Function Reference: Y
@year
@ytd
Function Reference: Z
@zeros
Wildcards
Wildcard Expressions
Using Wildcard Expressions
Source and Destination Patterns
Resolving Ambiguities
Wildcard versus Multiplication
Wildcard versus Pool Identifier
Object Reference
Object View and Procedure Reference
Alpha
alpha
clearhist
clearremarks
copy
display
displayname
dups
freq
frml
genr
label
makemap
map
olepush
setattr
setindent
setjust
sheet
sort
Coef
clearcollabels
clearhist
clearremarks
clearrowlabels
coef
copy
display
displayname
export
fill
import
label
olepush
read
resize
setattr
setcollabels
setformat
setindent
setjust
setrowlabels
setwidth
sheet
showlabels
stats
write
Equation
abtest
arch
archtest
ardl
arma
auto
binary
boundstest
breakls
breakspec
breaktest
cdtest
cellipse
censored
chow
cinterval
clearhist
clearremarks
coefcov
coeflabel
coefmatrix
coefpath
coefscale
coint
cointgraph
cointreg
cointrel
cointrep
copy
correl
correlsq
count
cvardecomp
cvgraph
depfreq
derivs
did
didcs
didgbdecomp
didmakeeq
didtrends
display
displayname
dynmult
ecresults
effects
endogtest
enet
equation
facbreak
fit
fitoutliers
fixedtest
forecast
funbias
funbw
funci
funcoef
funcov
funtest
garch
glm
gmm
grads
heckit
hettest
hist
icgraph
ictable
infbetas
infstats
instsum
label
lambdacoefs
lambdaest
lambdafit
lambdapath
liml
logit
ls
lvageplot
makecoint
makederivs
makefunobj
makegarch
makegrads
makelimits
makemodel
makeregs
makeresids
makergmprobs
makestrwgts
maketransprobs
means
midas
modselgraph
modseltable
multibreak
newsimpact
nyblom
olepush
ordered
orthogtest
outliers
output
paths
pmghausmantest
predict
probit
qrcrprocess
qrecprocess
qreg
qrprocess
qrslope
qrsymm
ranhaus
rcomptest
representations
reset
resids
resoutliers
results
rgmprobs
rls
robustls
setattr
setpilotbw
signbias
similarity
srcoefs
strconstant
strlinear
strnonlin
strwgts
switchreg
symmtest
testadd
testdrop
testfit
threshold
transprobs
tsls
ubreak
updatecoefs
varinf
varsel
wald
weakinst
white
Factor
anticov
clearhist
clearremarks
copy
display
displayname
eigen
factnames
factor
fitstats
fitted
fsel
gls
ipf
label
loadings
makescores
maxcor
ml
msa
observed
olepush
output
pace
partcor
pf
reduced
resids
rotate
rotateclear
rotateout
setattr
scores
smc
structure
uls
Geomap
addtext
addtitle
attr
autocrop
clearhist
clearremarks
copy
display
displayname
formatshapelabel
geomap
hide
label
legend
link
load
makeattrser
map
mask
movetitle
olepush
options
save
setattr
setfillcolor
options
setfont
setjust
setshapelabel
show
unmask
Graph
addarrow
addellipse
addrect
addtext
align
axis
bplabel
clearhist
clearremarks
copy
datalabel
datelabel
dates
delete
display
displayname
draw
drawdefault
graph
label
legend
makegroup
merge
metafile
name
olepush
options
save
scale
setattr
setbpelem
setelem
setfont
setobslabel
setupdate
sort
template
textdefault
update
Group
add
cause
cdfplot
clearcontents
clearhist
clearremarks
coint
copy
cor
correl
cov
cross
ddloadtmpl
ddrowopts
ddsavetmpl
ddtabopts
deleteobs
display
displayname
distdata
drop
dtable
dups
freq
group
insertobs
kerfit
label
linefit
lrcov
olepush
makepcomp
makesystem
makewhiten
members
nnfit
pcomp
reorder
resample
setattr
setfillcolor
setformat
setindent
setjust
settextcolor
setwidth
sheet
sort
stats
testbtw
uroot
uroot2
Link
clearhist
clearremarks
copy
display
displayname
label
link
linkto
olepush
setattr
Logl
append
cellipse
checkderivs
clearhist
clearremarks
coefcov
copy
display
displayname
grads
label
logl
makegrads
makemodel
ml
olepush
output
results
setattr
spec
updatecoefs
wald
Matrix
clearcollabels
clearhist
clearremarks
clearrowlabels
copy
cor
cov
display
displayname
distdata
export
fill
freq
import
label
makepcomp
matrix
olepush
pcomp
read
resample
resize
setattr
setcollabels
setformat
setindent
setjust
setrowlabels
setwidth
sheet
showlabels
stats
testbtw
testbtw
write
Model
addassign
addinit
addover
adjust
append
block
boundscheck
clearhist
clearremarks
compare
control
copy
display
displayname
drop
droplink
endog
eqs
exclude
digraph
fliptype
innov
label
makeendog
makegraph
makegroup
merge
model
msg
olepush
override
printview
reinclude
replace
replacelink
replacevar
revert
scenario
scenlist
setattr
setbounds
settrace
solve
solveopt
spec
stochastic
text
trace
track
undoflip
unlink
update
vars
Pool
add
cellipse
clearhist
clearremarks
coefcov
coint
copy
define
delete
describe
display
displayname
drop
fetch
fixedtest
genr
label
ls
makegroup
makemodel
makeresids
makestats
makesystem
olepush
output
pool
ranhaus
read
representations
residcor
residcov
resids
results
setattr
sheet
store
testadd
testdrop
tsls
updatecoefs
uroot
uroot2
wald
write
Rowvector
clearcollabels
clearhist
clearremarks
clearrowlabels
copy
display
displayname
distdata
edftest
export
fill
freq
hist
import
label
olepush
read
resize
rowvector
setattr
setcollabels
setformat
setindent
setjust
setrowlabels
setwidth
sheet
showlabels
stats
teststat
write
stats
Sample
clearhist
clearremarks
copy
display
displayname
label
olepush
sample
set
setattr
spec
Scalar
clearhist
clearremarks
copy
display
displayname
label
olepush
scalar
setattr
sheet
Series
adjust
autoarma
bdstest
boxplotby
bpf
bubbletest
buroot
cdfplot
cdtest
changepoints
classify
clearcontents
clearhist
clearremarks
copy
correl
display
displayname
distdata
dsa
dups
edftest
ets
fill
forcavg
forceval
freq
frml
genr
hist
hpf
insertobs
ipolate
jdemetra
kdensity
label
lrvar
makepanpcomp
makewavelets
makewhiten
map
movereg
olepush
outliers
pancov
panpcomp
prophet
resample
seas
seasuroot
series
setattr
setconvert
setfillcolor
setformat
setindent
setjust
settextcolor
setwidth
sheet
smooth
sort
statby
stats
stl
testby
teststat
tramoseats
trendtests
uroot
uroot2
vratio
waveanova
wavedecomp
waveoutlier
wavethresh
x11
x12
x13
References
Spool
addfolder
append
clearhist
clearremarks
comment
copy
display
displayname
extract
flatten
graphmode
hide
horizindent
insert
label
leftmargin
move
name
olepush
options
print
remove
save
setattr
setfont
setzoom
show
spool
tablemode
title
topmargin
vertindent
vertspacing
width
Sspace
append
cellipse
clearhist
clearremarks
coefcov
copy
display
displayname
endog
forecast
grads
label
makeendog
makefilter
makegrads
makemodel
makeresids
makesignals
makestates
ml
olepush
output
residcor
residcov
resids
results
setattr
signalgraphs
spec
sspace
statefinal
stategraphs
stateinit
structure
updatecoefs
wald
String
clearhist
clearremarks
copy
display
displayname
label
list
olepush
setattr
sheet
string
Svector
clearcollabels
clearhist
clearremarks
clearrowlabels
copy
display
displayname
export
fill
freq
import
label
olepush
resize
setattr
setcollabels
setrowlabels
sheet
showlabels
svector
Sym
clearcollabels
clearhist
clearremarks
clearrowlabels
copy
cor
cov
display
displayname
eigen
export
fill
import
label
olepush
read
resize
setattr
setcollabels
setformat
setindent
setjust
setrowlabels
setwidth
sheet
showlabels
stats
sym
write
System
3sls
append
arch
autospec
cellipse
clearhist
clearremarks
coefcov
copy
correl
derivs
display
displayname
endog
estcov
fiml
garch
gmm
grads
jbera
label
ls
makeendog
makegarch
makeloglike
makemodel
makeresids
olepush
output
qstats
representations
residcor
residcov
resids
results
setattr
spec
sur
system
tsls
updatecoefs
wald
wls
wtsls
Table
clearhist
clearremarks
comment
copy
copyrange
copytable
deletecells
deletecol
deleterow
display
displayname
fixcol
fixrow
fixrowcol
insertcells
insertcol
insertrow
insertrow
label
olepush
save
setattr
setfillcolor
setfont
setformat
setheight
setindent
setjust
setlines
setmerge
setprefix
setsuffix
settextcolor
setwidth
sheet
sort
table
title
transpose
Text
append
clear
clearhist
clearremarks
copy
display
displayname
label
olepush
save
setattr
svector
text
Userobj
add
clear
clearhist
clearremarks
copy
display
displayname
drop
extract
label
members
olepush
setattr
userobj
Valmap
append
clearhist
clearremarks
copy
displayname
label
olepush
setattr
sheet
stats
usage
valmap
Var
append
arlm
arroots
btvcvar
bvar
clearhist
clearremarks
cleartext
coint
copy
correl
display
displayname
ec
drawcoefs
drawrescov
endog
fit
forecast
hdecomp
impulse
jbera
label
laglen
ls
makecoefs
makecoint
makeendog
makeess
makeif
makemodel
makergmprobs
makeresids
makerne
makesystem
maketransprobs
mfvar
olepush
output
postdraws
postresidcov
qstats
representations
residcor
residcov
resids
results
rgmprobs
setattr
svar
switchvar
testexog
testlags
transprobs
var
vdecomp
white
References
Vector
classify
clearcollabels
clearhist
clearremarks
clearrowlabels
copy
cov
display
displayname
distdata
edftest
export
fill
freq
getglobalc
hist
import
label
olepush
read
resample
resize
setattr
setcollabels
setformat
setglobalc
setindent
setjust
setrowlabels
setwidth
sheet
showlabels
statby
stats
testby
teststat
vector
write
Graph Creation Commands
Graph Creation Command Summary
Graph Creation Object Summary
area
band
bar
boxplot
bubble
bubbletrip
distplot
dot
errbar
hilo
line
mixed
pie
qqplot
scat
scatmat
scatpair
seasplot
spike
xyarea
xybar
xyerrbar
xyline
xypair
Optional Graph Components
Categorical Spec
Auxiliary Spec
Object Command Summary
Object Summary
Symbols
Numerics
A
B
C
D
E
F
G
H
I
J
K
L
M
N
O
P
Q
R
S
T
U
V
W
X
Y
Z
Index
Z
wnewpage_rtf
seasonal_rtf
CensusX13_rtf
CensusX12_rtf
addins_rtf
userobj_rtf
wffunction_rtf
expression_rtf
stringref_rtf
dateref_rtf
matrix_summary_rtf
matrix_language_rtf
matrix_rtf
program_rtf
commands_rtf
function_rtf
objects_rtf
alpha_attr
alpha_description
alpha_detailedtype
alpha_displayname
alpha_first
alpha_firstall
alpha_hilo
alpha_last
alpha_lastall
alpha_lohi
alpha_name
alpha_remarks
alpha_type
alpha_updatetime
alpha_i
alpha_elem
coef_attr
coef_collabels
coef_description
coef_detailedtype
coef_displayname
coef_name
coef_remarks
coef_rowlabels
coef_rows
coef_type
coef_updatetime
coef_i
equation_aic
equation_bylist
equation_scalar_coefcov
equation_scalar_coefs
equation_deviance
equation_deviancestat
equation_df
equation_dispersion
equation_dw
equation_f
equation_finalbw
equation_fixeddisp
equation_fprob
equation_hacbw
equation_hq
equation_instrank
equation_jstat
equation_jprob
model_lambdamin
equation_limlk
equation_logl
equation_lrprob
equation_lrstat
equation_lrvar
equation_meandep
equation_nbreaks
equation_ncases
equation_nclusters
equation_ncoef
equation_ncross
equation_npers
equation_nregimes
equation_nthresholds
equation_ntreatment
equation_objective
equation_pearsonssr
equation_pearsonstat
equation_pilotbw
equation_qlrprob
equation_qlrstat
equation_quantdep
equation_r2
equation_rbar2
equation_rdeviance
equation_regobs
equation_rlogl
equation_rmse
equation_rn2
equation_robf
equation_robfprob
equation_robjective
equation_rw2
equation_schwarz
equation_sddep
equation_se
equation_sparsity
equation_ssr
equation_ssr2
equation_scalar_stderrs
equation_scalar_thresholds
equation_scalar_tstats
equation_wmeandep
equation_wgtscale
equation_c
equation_ardlceccoefs
equation_ardleccoefs
equation_ardlcoint
equation_ardllrcoefs
equation_ardlsrcoefs
equation_ardlsrses
equation_vec_coefcov
equation_vec_coefs
equation_contempcov
equation_cvconverge
equation_cvisvalid
equation_cviters
equation_cvresults
equation_effects
equation_fcgrid
equation_initprobs
equation_instwgt
equation_lambdaest
equation_lambdacoefs
equation_lambdapath
equation_lambda2cov
equation_lrcov
equation_cvsummary
equation_pmgcxcoefs
equation_pmgcxses
equation_pmglrcoefs
equation_pmgsrcoefs
equation_pvals
equation_vec_stderrs
equation_vec_thresholds
equation_vec_tstats
equation_ardlcointsubst
equation_attr
equation_breaks
equation_coeflabels
equation_coeflist
equation_command
equation_depends
equation_description
equation_detailedtype
equation_displayname
equation_esteq
equation_extralist
equation_instlist
equation_method
equation_name
equation_options
equation_remarks
equation_smpl
equation_spec
equation_subst
equation_type
equation_updatetime
equation_varlist
factor_valid
factor_nvars
factor_nfactors
factor_obs
factor_balanced
factor_ncondition
factor_pratio
factor_nnfi
factor_rfi
factor_nfi
factor_ifi
factor_cfi
factor_params
factor_ncoefs
factor_objective
factor_discrep
factor_aic
factor_sc
factor_hq
factor_ecvi
factor_chisq
factor_chisqdf
factor_chisqprob
factor_bartlett
factor_bartlettprob
factor_rmsr
factor_srmsr
factor_gfi
factor_agfi
factor_noncent
factor_gammahat
factor_mdnoncent
factor_rmsea
factor_obsmat
factor_cov
factor_scaled
factor_fitted
factor_common
factor_resid
factor_residcommon
factor_reduced
factor_ireduced
factor_anticov
factor_partcor
factor_iunique
factor_unique
factor_icommunal
factor_communal
factor_rowadjust
factor_loadings
factor_rloadings
factor_rotmat
factor_rotmatinv
factor_factcor
factor_factstruct
factor_attr
factor_command
factor_description
factor_detailedtype
factor_displayname
factor_factnames
factor_method
factor_name
factor_options
factor_smpl
factor_spec
factor_type
factor_updatetime
factor_varnames
geomap_@minx
geomap_@maxx
geomap_@miny
geomap_@maxy
geomap_@count
geomap_@id
geomap_attr
geomap_description
geomap_detailedtype
geomap_displayname
geomap_ids
geomap_name
geomap_remarks
geomap_type
geomap_updatetime
graph_axismin
graph_axismax
graph_axispos
graph_attr
graph_description
graph_detailedtype
graph_displayname
graph_members
graph_name
graph_remarks
graph_type
graph_updatetime
group_i
group_comobs
group_count
group_minobs
group_maxobs
group_attr
group_description
group_depends
group_detailedtype
group_displayname
group_members
group_name
group_remarks
group_seriesname
group_type
group_updatetime
link_attr
link_description
link_detailedtype
link_displayname
link_first
link_firstall
link_last
link_lastall
link_name
link_remarks
link_type
link_updatetime
logl_byeqn_statement
logl_byobs_statement
logl_deriv_statement
logl_derivstep_statement
logl_logl_statement
logl_param_statement
logl_temp_statement
logl_aic
logl_scalar_coefcov
logl_scalar_coefs
logl_hq
logl_linecount
logl_logl
logl_ncoefs
logl_regobs
logl_sc
logl_scalar_stderrs
logl_scalar_tstats
logl_vec_coefcov
logl_vec_coefs
logl_vec_pvals
logl_vec_stderrs
logl_vec_tstats
logl_attr
logl_command
logl_description
logl_detailedtype
logl_displayname
logl_line
logl_method
logl_name
logl_remarks
logl_smpl
logl_svector
logl_svectornb
logl_type
logl_updatetime
matrix_attr
matrix_collabels
matrix_description
matrix_detailedtype
matrix_displayname
matrix_name
matrix_remarks
matrix_rowlabels
matrix_type
matrix_updatetime
matrix_ij
matrix_cols
matrix_rows
matrix_col
matrix_diag
matrix_dropboth
matrix_dropcol
matrix_droprow
mat_icol
mat_irow
matrix_row
matrix_sub
model_bounds
model_attr
model_description
model_detailedtype
model_displayname
model_droppedaf
model_droppedafdep
model_name
model_remarks
model_scenarios
model_type
model_updatetime
model_addfactors
model_aflist
model_depends
model_endoglist
model_excludelist
model_exoglist
model_identity
model_overridelist
model_olist
model_linklist
model_spec
model_stochastic
model_upends
model_varlist
pool_attr
pool_command
pool_crossids
pool_crossidsest
pool_description
pool_detailedtype
pool_displayname
pool_idname
pool_idnameest
pool_method
pool_name
pool_options
pool_remarks
pool_smpl
pool_spec
pool_type
pool_updatetime
pool_aic
pool_scalar_coefcov
pool_scalar_coefs
pool_dw
pool_scalar_effects
pool_f
pool_logl
pool_meandep
pool_ncoef
pool_ncross
pool_ncrossest
pool_npers
pool_r2
pool_rbar2
pool_regobs
pool_schwarz
pool_sddep
pool_se
pool_ssr
pool_scalar_stderrs
pool_totalobs
pool_scalar_tstats
pool_c
pool_coefcov
pool_vec_coefs
pool_vec_effects
pool_residcov
pool_vec_stderrs
pool_vec_tstats
rowvector_attr
rowvector_collabels
rowvector_description
rowvector_detailedtype
rowvector_displayname
rowvector_name
rowvector_remarks
rowvector_rowlabels
rowvector_type
rowvector_updatetime
rowvector_i
rowvector_cols
rowvector_dropcol
rowvec_icol
sample_attr
sample_description
sample_detailedtype
sample_displayname
sample_name
sample_remarks
sample_type
sample_updatetime
scalar_attr
scalar_description
scalar_detailedtype
scalar_displayname
scalar_name
scalar_remarks
scalar_type
scalar_updatetime
series_attr
series_description
series_depends
series_detailedtype
series_displayname
series_first
series_firstall
series_hilo
series_last
series_lastall
series_lohi
series_name
series_remarks
series_type
series_updatetime
series_obs
series_i
series_elem
spool_attr
spool_description
spool_detailedtype
spool_displayname
spool_name
spool_objname
spool_objtype
spool_remarks
spool_type
spool_updatetime
spool_count
spool_totalcount
sspace_scalar_coefcov
sspace_scalar_coefs
sspace_scalar_eqncoef
sspace_eqregobs
sspace_linecount
sspace_sddep
sspace_ssr
sspace_scalar_stderrs
sspace_scalar_tstats
sspace_aic
sspace_hq
sspace_logl
sspace_ncoefs
sspace_neqns
sspace_regobs
sspace_sc
sspace_totalobs
sspace_vec_coefcov
sspace_vec_coefs
sspace_final_state
sspace_final_statecov
sspace_init_state
sspace_init_statecov
sspace_pvals
sspace_residcov
sspace_vec_stderrs
sspace_vec_tstats
sspace_pred_signal
sspace_pred_signalcov
sspace_pred_signalse
sspace_pred_err
sspace_pred_errcov
sspace_pred_errcovinv
sspace_pred_errse
sspace_pred_errstd
sspace_pred_state
sspace_pred_statecov
sspace_pred_statese
sspace_pred_stateerr
sspace_curr_err
sspace_curr_gain
sspace_curr_state
sspace_curr_statecov
sspace_curr_statese
sspace_sm_signal
sspace_sm_signalcov
sspace_sm_signalse
sspace_sm_signalerr
sspace_sm_signalerrcov
sspace_sm_signalerrse
sspace_sm_signalerrstd
sspace_sm_state
sspace_sm_statecov
sspace_sm_statese
sspace_sm_stateerr
sspace_sm_stateerrcov
sspace_sm_stateerrse
sspace_sm_stateerrstd
sspace_sm_crosserrcov
sspace_attr
sspace_command
sspace_description
sspace_detailedtype
sspace_displayname
sspace_line
sspace_name
sspace_options
sspace_remarks
sspace_smpl
sspace_svector
sspace_svectornb
sspace_type
sspace_updatetime
string_attr
string_description
string_detailedtype
string_displayname
string_name
string_remarks
string_type
string_updatetime
svector_collabels
svector_detailedtype
svector_displayname
svector_name
svector_remarks
svector_rowlabels
svector_type
svector_updatetime
svector_rows
svector_attr
svec_irow
svector_description
sym_attr
sym_collabels
sym_description
sym_detailedtype
sym_displayname
sym_name
sym_remarks
sym_rowlabels
sym_updatetime
sym_ij
sym_cols
sym_rows
sym_col
sym_diag
sym_drop
sym_dropboth
sym_dropcol
sym_droprow
sym_icol
sym_irow
sym_row
sym_sub
sym_type
system_scalar_coefcov
system_scalar_coefs
system_dw
system_eqncoef
system_eqregobs
system_meandep
system_r2
system_rbar2
system_sddep
system_se
system_ssr
system_scalar_stderrs
system_scalar_tstats
system_c
system_aic
system_detresid
system_hq
system_jstat
system_linecount
system_logl
system_ncoefs
system_neqn
system_regobs
system_schwarz
system_totalobs
system_vec_coefcov
system_vec_coefs
system_estcov
system_pvals
system_residcov
system_vec_stderrs
system_vec_tstats
system_attr
system_command
system_description
system_detailedtype
system_displayname
system_line
system_method
system_name
system_options
system_remarks
system_smpl
system_svector
system_svectornb
system_type
system_updatetime
table_ij
table_attr
table_description
table_detailedtype
table_displayname
table_name
table_remarks
table_title
table_type
table_updatetime
table_cols
table_colwidth
table_rowheight
table_rows
table_val
text_linecount
text_attr
text_description
text_detailedtype
text_displayname
text_line
text_name
text_remarks
text_svector
text_svectornb
text_type
text_updatetime
userobj_attr
userobj_description
userobj_detailedtype
userobj_displayname
userobj_members
userobj_name
userobj_remarks
userobj_type
userobj_updatetime
userobj_hasmember
valmap_attr
valmap_description
valmap_detailedtype
valmap_displayname
valmap_name
valmap_remarks
valmap_type
valmap_updatetime
var_eqlogl
var_eqncoef
var_eqregobs
var_meandep
var_r2
var_rbar2
var_sddep
var_se
var_ssr
var_a
var_b
var_c
var_aic
var_detresid
var_hq
var_lagcount
var_lagorder
var_logl
var_ncoefs
var_neqn
var_nrestrict
var_regobs
var_sc
var_svarcvgtype
var_svaroverid
var_totalobs
var_coefmat
var_coefse
var_cointadj
var_cointadjse
var_cointlr
var_cointlrse
var_cointse
var_cointsr
var_cointsrse
var_cointvec
var_companion
var_impfact
var_lagcoefs
var_lagcoef
var_lagids
var_lrrsp
var_lrrspse
var_postresidcov
var_residcov
var_svaramat
var_svarbmat
var_svarcovab
var_svarfmat
var_svarrcov
var_svarsmat
var_swcompanion
var_swimpfact
var_swlagcoefs
var_lagcoefsum
var_attr
var_command
var_description
var_detailedtype
var_displayname
var_method
var_name
var_options
var_remarks
var_smpl
var_type
var_updatetime
vec_attr
vec_collables
vec_description
vec_detailedtype
vec_displayname
vec_name
vec_remarks
vec_rowlabels
vec_type
vec_updatetime
vec_i
vec_rows
vec_droprow
vec_irow
vec_row
matrix_t
