Command Reference : Function Reference : Function Reference: T
@trendc
Calendar trend.
Syntax: @trendc([d])
d: (optional) date or observation
Return: series
Returns a calendar time trend that increases by the number of calendar periods between successive observations.
The optional date or observation d may be provided to indicate the starting point (with a 0 value) for the trend. If d omitted, the starting point is assumed to be the earliest observation in the workfile.
In a regular frequency workfile, @trend and @trendc both return a simple trend that increases by one for each observation of the workfile.
In an irregular workfile, @trend provides an observation-based trend as before, but @trendc now returns a calendar trend that increases based on the number of calendar periods between adjacent observations. For example, in a daily irregular file where a Thursday has been omitted because it was a holiday, the @trendc value would increase by two between the Wednesday before and the Friday after the holiday, while @trend will increase by only one.
This function is panel aware. For a panel trend function that uses only the observed dates, use @trend. For a simple panel trend in which values begin at 1 and sequentially increase by 1, you may use the @obsid function.
series t = @trend
creates a calendar trend series starting at 0 in the first workfile observation.
series t90q1 = @trend("1990q1")
creates a calendar trend series based at 0 in 1990q1.
See also @trend, @trendbr, and @obsid.
