Trend coefficient from detrending regression.
Computes the trend coefficient (or coefficients for panel data) of an OLS regression versus a constant and an implicit time trend.
Syntax: @trendcoef(x[, s])
x: series, vector, matrix
s: (optional) sample string or object when x is a series and assigning to series
Return: number
Returns the trend coefficient of an OLS regression on matrix or vector m versus a constant and an implicit time trend, as in @detrend.
When applied to a matrix, the matrix elements are arranged in vectorization order and then paired with the implicit time trend.
This function is panel aware.
series y = 2 + 3 * @trend + @nrnd
= @trendcoef(y)
The first line generates the series y using a simple linear regression model, where the sole regressor is a time trend, the intercept is 2, and the slope coefficient is 3. The second line returns the OLS estimate of the slope coefficient, and is approximately 3 in large samples.
The following commands begin by creating a workfile, generating a random series, and then converting to a vector so that we can compute identical results using the series and the vector.
workfile u 100
series y = nrnd
vector yv = @convert(y)
The trend regression trend coefficient estimate is given by
scalar tr1 = @trendcoef(yv)
Alternately, the trend regression results may be obtained using the vector YV using the @regress command on the augmented data matrix:
matrix vcoefs = @regress(@hcat(yv, @ones(yv.@rows), @range(0, yv.@rows-1)))
The first column of VCOEFS contains the intercept and trend coefficient, so
scalar tr2 = vcoefs(2)
is the trend coefficient.
Estimates may also be obtained using the series and an equation object
equation eq1.ls y c @trend
scalar tr3 = eq1.c(2)
