Object Reference : Object View and Procedure Reference : Geomap
movetitle
Moves the title in the geomap to the specified location.
geomap_name.movetitle(position)
where position can be one of the following:
ctm
Center top map.
ltm
Left top map.
rtm
Right top map.
cbm
Center bottom map.
lbm
Left bottom map.
rbm
Right bottom map.
lmm
Left middle map.
rmm
Right middle map.
lmp
Left-middle of point.
rmp
Right-middle of point.
lap
Left above point.
rap
Right above point.
lbp
Left below point.
rbp
Right below point.
cap
Center above point.
cbp
Center below point.
You can also use explicit coordinates to specify the position of the upper left corner of the text.
Coordinates are set by a pair of numbers h, v in map units. Use the geomap data members @minx, @miny, @maxx, and @maxy to obtain the position limits.
Coordinates may be used with other options, but they must be in the first two positions of the options list. Coordinates are overridden by other options that specify location.
geomap01.movetitle(lbm)
moves the current title of the geomap object GEOMAP1 to the left bottom corner.
geomap01.movetitle(400, 400, rmp)
moves the title of the geomap object GEOMAP1 to the right of the point (400, 400) in the map.
See “Geomaps” for a discussion of geomaps.
