causes
is to see how much of the current
can be explained by past values of
and then to see whether adding lagged values of
can improve the explanation.
is said to be Granger-caused by
if
helps in the prediction of
, or equivalently if the coefficients on the lagged
’s are statistically significant. Note that two-way causation is frequently the case;
Granger causes
and
Granger causes
Granger causes
” does not imply that
is the effect or the result of
. Granger causality measures precedence and information content but does not by itself indicate causality in the more common use of the term.
, that corresponds to reasonable beliefs about the longest time over which one of the variables could help predict the other.![]() | (12.62) |
series in the group. The reported F-statistics are the Wald statistics for the joint hypothesis:![]() | (12.63) |
does not Granger-cause
in the first regression and that
in the second regression.
