Object Reference : Object View and Procedure Reference : Scalar
label
Display or change the label view of the scalar object, including the last modified date and display name (if any).
scalar_name.label
scalar_name.label(options) text
To modify the label, you should specify one of the following options along with optional text. If there is no text provided, the specified field will be cleared:
c
Clears all text fields in the label.
d
Sets the description field to text.
s
Sets the source field to text.
u
Sets the units field to text.
r
Appends text to the remarks field as an additional line.
p
Print the label view.
The following lines replace the remarks field of the scalar S1 with “Mean of Dependent Variable from EQ3”:
s1.label(r)
s1.label(r) Mean of Dependent Variable EQ3
See “Labeling Objects” for a discussion of labels.
