Insert string into a string.
Syntax:		@insert(str1, str2, n)
	str1:	string
	str2:	string
	n:	integer
Return:		string
Inserts the string str2 into the string str1 at the position given by the integer n.
string sval1 = "I believe it can be done"
string sval2 = "not "
@insert("I believe it can be done", "not ", 16)
@insert(sval1, sval2, 16)
@insert(sval1, "not ", 16)
all return the string “I believe it cannot be done”.
If ALPHA1 is an alpha series,
alpha a1 = @insert(sval2, not ", 5)
creates an alpha series with the contents of ALPHA1 with the string “not ” at position 5, for each observation in the workfile sample.
alpha a2 = @insert(sval1, a1, ser1)
inserts SVAL1 into A1 using the integer positions given in the series SER1.
If SVEC1 is an svector,
svector s1 = @insert("(pretty please) ", svec1, 10)
inserts “(pretty please) ” into SVEC at position 10.
