Object Reference : Object View and Procedure Reference : System
gmm
Estimation by generalized method of moments (GMM).
The system object must be specified with a list of instruments.
system_name.gmm(options)
m=integer
Maximum number of iterations.
c=number
Set convergence criterion. The criterion is based upon the maximum of the percentage changes in the scaled coefficients. The criterion will be set to the nearest value between 1e-24 and 0.2.
l=number
Set maximum number of iterations on the first-stage iteration to get the one-step weighting matrix.
numericderiv / ‑numericderiv
[Do / do not] use numeric derivatives only. If omitted, EViews will follow the global default.
fastderiv / ‑fastderiv
[Do / do not] use fast derivative computation. If omitted, EViews will follow the global default.
showopts / ‑showopts
[Do / do not] display the starting coefficient values and estimation options in the estimation output.
w
Use White’s diagonal weighting matrix (for cross section data).
b=arg (default=“nw”)
Specify the bandwidth: “nw” (Newey-West fixed bandwidth based on the number of observations), number (user specified bandwidth), “v” (Newey-West automatic variable bandwidth selection), “a” (Andrews automatic selection).
q
Use the quadratic kernel. Default is to use the Bartlett kernel.
n
Prewhiten by a first order VAR before estimation.
i
Iterate simultaneously over the weighting matrix and the coefficient vector.
s
Iterate sequentially over the weighting matrix and coefficient vector.
o (default)
Iterate only on the coefficient vector with one step of the weighting matrix.
c
One step (iteration) of the coefficient vector following one step of the weighting matrix.
e
TSLS estimates with GMM standard errors.
prompt
p
Print results.
Note that some options are only available for a subset of specifications.
For system estimation, the command:
sys1.gmm(b=a, q, i)
estimates the system SYS1 by GMM with a quadratic kernel, Andrews automatic bandwidth selection, and iterates simultaneously over the weight and coefficient vectors until convergence.
See “Additional Regression Tools” and “System Estimation” for discussion of the various GMM estimation techniques.
