tsls |
m=integer | Set maximum number of iterations. |
c=number | Set convergence criterion. The criterion is based upon the maximum of the percentage changes in the scaled coefficients. The criterion will be set to the nearest value between 1e-24 and 0.2. |
numericderiv / ‑numericderiv | [Do / do not] use numeric derivatives only. If omitted, EViews will follow the global default. |
fastderiv / ‑fastderiv | [Do / do not] use fast derivative computation. If omitted, EViews will follow the global default. |
showopts / ‑showopts | [Do / do not] display the starting coefficient values and estimation options in the estimation output. |
i | Iterate on the weighting matrix and coefficient vector simultaneously. |
s | Iterate on the weighting matrix and coefficient vector sequentially. |
o (default) | Iterate only on the coefficient vector with one step of the weighting matrix. |
c | One step iteration of the coefficient vector after one step of the weighting matrix. |
l=number | Set maximum number of iterations on the first-stage iteration to get one-step weighting matrix. |
p | Print estimation results. |
