Object Reference : Object View and Procedure Reference : Table
transpose
Transposes a set of cells in the table.
table_name.transpose(cell_range)
where cell_range can take one of the following forms:
@all
Apply to all cells in the table.
cell
Cell identifier. You can identify cells using either the column letter and row number (e.g., “A1”), or by using “R” followed by the row number, followed by “C” and the column number (e.g., “R1C2”).
row[,] col
Row number, followed by column letter or number, separated by “,” (e.g., “2,C”, or “2,3”). Apply to cell.
row
Row number (e.g., “2”). Apply to all cells in the row.
col
Column letter (e.g., “B”). Apply to all cells in the column.
first_cell[:]last_cell,
first_cell[,]last_cell
Top left cell of the selection range (specified in “cell” format), followed by bottom right cell of the selection range (specified in “cell” format), separated by a “:” or “,” (e.g., “A2:C10”, “A2,C10”, or “R2C1:R10C3”, “R2C1,R10C3”). Apply to all cells in the rectangular region defined by the first cell and last cell.
first_cell_row[,] first_cell_col[,]
last_cell_row[,] last_cell_col
Top left cell of the selection range (specified in “row[,] col” format), followed by bottom right cell of the selection range (specified in “row[,] col” format), separated by a “,” (e.g., “2,A,10,C” or “2,1,10,3”). Apply to all cells in the rectangular region defined by the first cell and last cell.
To rotate the cells in column 1 to row 1 in table TAB1:
tab1.transpose(A)
To rotate all of the cells in TAB1:
tab1.transpose(@all)
To rotate the cells in range B11:C20 to range B11:K12:
tab1.transpose(b11:c20)
