The VEC estimation output consists of two parts. The first part reports the results from the first step Johansen procedure. If you did not impose restrictions, EViews will use a default normalization that identifies all cointegrating relations. This default normalization expresses the first
variables in the VEC as functions of the remaining
variables, where
is the number of cointegrating relations and
is the number of endogenous variables. Asymptotic standard errors (corrected for degrees of freedom) are reported for parameters that are identified under the restrictions. If you provided your own restrictions, standard errors will not be reported unless the restrictions identify all cointegrating vectors.
The second part of the output reports results from the second step VAR in first differences, including the error correction terms estimated from the first step. The error correction terms are denoted
CointEq1,
CointEq2, and so on in the output. This part of the output has the same format as the output from unrestricted VARs as explained in
“Estimation Output”, with one difference. At the bottom of the VEC output table, you will see two log likelihood values reported for the system. The first value, labeled
Log Likelihood (d.f. adjusted), is computed using the determinant of the residual covariance matrix (reported as
Determinant Residual Covariance), using a small sample degrees of freedom correction. This is the log likelihood value reported for unrestricted VARs. The
Log Likelihood value is computed using the residual covariance matrix without correcting for degrees of freedom. This log likelihood value is comparable to the one reported in the cointegration test output.
