export |
t=file_type (default=“csv”) | Specifies the file type, where file_type may be one of: “excelxml” (Excel 2007 (xml)),“csv” (CSV - comma-separated), “rtf” (Rich-text format), “txt” (tab-delimited text), “html” (HTML - Hypertext Markup Language), “emf” (Enhanced Metafile), “pdf” (PDF - Portable Document Format), “tex” (LaTeX), or “md” (Markdown). Files will be saved with the “.xlsx”, “.csv”, “.rtf”, “.txt”, “.htm”, “.emf”, “.pdf”, “.tex”, or “.md” extensions, respectively. |
s=arg | Scale size, where arg is from 5 to 200, representing the percentage of the original table size (only valid for HTML or RTF files). |
n=string | Replace all cells that contain NA values with the specified string. “NA” is the default. |
h / -h | Include(/do not include) column and row headers. The default is to not include the headers |
landscape | Save in landscape mode (the default is to save in portrait mode). |
size=arg (default=“letter”) | Page size: “letter”, “legal”, “a4”, and “custom”. |
width=number (default=8.5) | Page width in inches if “size=custom”. |
height=number (default=11) | Page height in inches if “size=custom”. |
leftmargin=number (default=0.5) | Left margin width in inches. |
rightmargin=number (default = 0.5) | Right margin width in inches. |
topmargin=number (default=1) | Top margin width in inches. |
bottommargin= number (default = 1) | Bottom margin width in inches. |
texspec / -texspec | [Include / Do not include] the full LaTeX documentation specification in the LaTeX output. The default behavior is taken from the global default settings. |
mode=arg | Specify whether to create a new file, overwrite an existing file, or update an existing file. arg may be “create” (create new file only; error on attempt to overwrite) or “update” (update an existing file, only overwriting the area specified by the range= table_description). If the “mode=” option is not used, EViews will create a new file, unless the file already exists in which case it will overwrite it. Note that the “mode=update” option is only available for Excel in 1) Excel versions through 2003, if Excel is installed, and 2) Excel 2007 (xml). Note: Excel does not need to be installed for Excel 2007 writing. |
cellfmt=arg | Specify whether to use EViews, pre-existing, or remove cell formatting (colors, font, number formatting when possible, column widths and row heights) for the written range. arg may be “eviews” (replace current formatting in the file with the same cell formatting in EViews), “preserve” (leave current cell formatting already in the Excel file), or “clear” (remove current formatting and do not replace). |
strlen=arg (default = 256) | Specify the maximum the number of characters written for cells containing text. Strings in cells which are longer the max, will be truncated. |
