User’s Guide : Advanced Single Equation Analysis : ARCH and GARCH Estimation : Additional ARCH Models
The Integrated GARCH (IGARCH) Model
The Threshold GARCH (TARCH or GJR-GARCH) Model
The Exponential GARCH (EGARCH) Model
The Power ARCH (PARCH) Model
The Component GARCH (CGARCH) Model
Fractionally Integrated GARCH and EGARCH (FIGARCH)
The Fractionally Integrated GARCH (FIGARCH) Model
Background
Estimating a FIGARCH model
The Fractionally Integrated Exponential GARCH (FIEGARCH) Model
Background
Estimating a FIEGARCH model
Mixed Data Sampling GARCH (MIDAS GARCH)
How to Estimate MIDAS GARCH in EViews
Working with MIDAS GARCH Equations
Representations
Coefficient Labels
User Specified Models
In addition to the standard GARCH specification, EViews lets you perform estimation assuming a number of models of the variance. These include Integrated GARCH (IGARCH), Threshold ARCH (TARCH or GJRARCH), Exponential GARCH (EGARCH), Power ARCH (PARCH), component GARCH (CGARCH), Fractionally Integrated GARCH and EGARCH (FIGARCH and FIEGARCH), and Mixed Data Sampling GARCH (MIDAS GARCH)
For many of these models, the user has the ability to choose the order, if any, of asymmetry.
If one drops the constant term and restricts the remaining parameters of the variance specification to sum to one,
(27.19)
such that
(27.20)
which gives an integrated GARCH specification. This model was originally described in Engle and Bollerslev (1986). To estimate this model, select IGARCH in the Restrictions drop-down menu for the GARCH/TARCH model.
Threshold ARCH and Threshold GARCH (TARCH or GJR-GARCH) were introduced independently by Zakoïan (1994) and Glosten, Jaganathan, and Runkle (1993). The generalized specification for the conditional variance is given by:
(27.21)
where if and 0 otherwise.
In this model, good news, , and bad news. , have differential effects on the conditional variance; good news has an impact of , while bad news has an impact of . If , bad news increases volatility, and we say that there is a leverage effect for the i-th order. If , the news impact is asymmetric.
Note that GARCH is a special case of the TARCH model where the threshold order is set to zero. To estimate a TARCH model, specify your GARCH model with ARCH and GARCH order and then change the Threshold order to the desired value.
The EGARCH or Exponential GARCH model was proposed by Nelson (1991). The specification for the conditional variance is:
(27.22)
Note that the left-hand side is the log of the conditional variance. This implies that the leverage effect is exponential, rather than quadratic, and that forecasts of the conditional variance are guaranteed to be nonnegative. The presence of leverage effects can be tested by the hypothesis that . The impact is asymmetric if .
There are two differences between the EViews specification of the EGARCH model and the original Nelson model. First, Nelson assumes that the follows a Generalized Error Distribution (GED), while EViews offers you a choice of normal, Student’s t-distribution, or GED. Second, Nelson's specification for the log conditional variance is a restricted version of:
which is an alternative parameterization of the specification above. Estimating the latter model will yield identical estimates to those reported by EViews except for the intercept term , which will differ in a manner that depends upon the distributional assumption and the order . For example, in a model with a normal distribution, the difference will be .
To estimate an EGARCH model, simply select the EGARCH in the model specification dropdown menu and enter the orders for the ARCH, GARCH and the Asymmetry order.
Notice that we have specified the mean equation using an explicit expression. The use of the explicit expression here is for illustration purposes only; since the expression is linear in the regressors, we could just as well have entered “dlog(ibm) c dlog(spx)” as our specification.
Taylor (1986) and Schwert (1989) introduced the standard deviation GARCH model, where the standard deviation is modeled rather than the variance. This model, along with several other models, is generalized in Ding et al. (1993) with the Power ARCH specification. In the Power ARCH model, the power parameter of the standard deviation can be estimated rather than imposed, and the optional parameters are added to capture asymmetry of up to order :
(27.23)
where , for , for all , and .
The symmetric model sets for all . Note that if and for all , the PARCH model is simply a standard GARCH specification. As in the previous models, asymmetric effects are present if .
To estimate this model, simply select the PARCH in the model specification dropdown menu and input the orders for the ARCH, GARCH and Asymmetric terms. EViews provides you with the option of either estimating or fixing a value for . To estimate the Taylor-Schwert's model, for example, you will to set the order of the asymmetric terms to zero and will set to 1.
The conditional variance in the GARCH(1, 1) model:
(27.24)
shows mean reversion to , which is a constant for all time. By contrast, the component model allows mean reversion to a varying level , modeled as:
(27.25)
Here is still the volatility, while takes the place of and is the time varying long-run volatility. The first equation describes the transitory component, , which converges to zero with powers of (). The second equation describes the long run component , which converges to with powers of . is typically between 0.99 and 1 so that approaches very slowly. We can combine the transitory and permanent equations and write:
(27.26)
which shows that the component model is a (nonlinear) restricted GARCH(2, 2) model.
To select the Component ARCH model, simply choose Component ARCH(1,1) in the Model dropdown menu. You can include exogenous variables in the conditional variance equation of component models, either in the permanent or transitory equation (or both). The variables in the transitory equation will have an impact on the short run movements in volatility, while the variables in the permanent equation will affect the long run levels of volatility.
An asymmetric Component ARCH model may be estimated by checking the Include threshold term checkbox. This option combines the component model with the asymmetric TARCH model, introducing asymmetric effects in the transitory equation and estimates models of the form:
(27.27)
where are the exogenous variables and is the dummy variable indicating negative shocks. indicates the presence of transitory leverage effects in the conditional variance.
Background
Background
EViews estimates Fractionally Integrated GARCH (FIGARCH) models, with support for both standard FIGARCH and Fractionally Integrated Exponential GARCH (FIEGARCH) specifications. The following discussion outlines the basic model and the interactive tools for estimating and working with FIGARCH models.
Background
While traditional GARCH models focus on short term dynamics of conditional variance, the fractionally integrated GARCH model (FIGARCH) model, introduced by Baillie, Bollerslev and Mikkelsen (1996, BBM), is designed to capture long run dependence properties of the variance.
Background
A standard GARCH model’s specification of the variance may be written as,
(27.28)
where and represent polynomial lags,
(27.29)
and is the lag operator.
The fractionally integrated GARCH (FIGARCH) model modifies this specification by introducing a fractional difference term. The FIGARCH variance may be written as,
(27.30)
where
(27.31)
and is the infinite lag operator
(27.32)
which uses the infinite lag expansion
(27.33)
In practice, the infinite lag expansion is truncated to a finite number. For example, BBM suggest truncation at 1000 lags.
To estimate a FIGARCH model, select ARCH - Autoregressive Conditional Heteroskedasticity in the Method dropdown at the bottom of the dialog to display the GARCH dialog, then, in the Variance and distribution specification section, choose FIGARCH in the Model dropdown menu:
As in other GARCH models, in the Mean equation section of the dialog, you should enter your variables or explicit equation and select your ARCH-M specification.
You may select the ARCH and GARCH orders, list any Variance regressors, and select the Error distribution.
Lastly, you may specify the FIGARCH Lag truncation number of terms in the FIGARCH infinite lag specification.
Background
The FIEGARCH model of Bollerslev and Mikkelsen (1996) adds FIGARCH long-memory innovations to EGARCH processes.
Background
Before proceeding, note that while FIEGARCH models can be specified for arbitrary ARCH and GARCH orders, researchers typically restrict both to a single lag, and EViews currently supports only these FIEGARCH(1,1) models.
The starting point for FIEGARCH is an EGARCH model that differs slightly from the model typically estimated by EViews (Equation 26.22). The log conditional variance for this new form of the EGARCH model variance is
(27.34)
where
(27.35)
and
(27.36)
For , substituting yields the EGARCH(1, 1) variance specification
(27.37)
which may be compared with the corresponding EGARCH(1, 1) using the EViews (Equation 26.22) alternative specification
(27.38)
The FIEGARCH model adds a long-run lag polynomial to Equation (27.34)
(27.39)
The corresponding FIEGARCH(1, 1) is given by
(27.40)
Substituting using yields
(27.41)
As with the FIGARCH model, in practice the infinite sums are truncated at a finite number, typically 1,000 terms.
To estimate a FIEGARCH model in EViews simply select ARCH - Autoregressive Conditional Heteroskedasticity in the Method dropdown at the bottom of the dialog to display the GARCH dialog, then choose FIEGARCH in the Variance and distribution specification section Model dropdown menu.
Note that since as EViews only supports the FIEGARCH(1, 1) specification, you may not specify the number of ARCH and GARCH terms.
You may, as for standard FIGARCH estimation, specify the Lag truncation number.
Representations
Coefficient Labels
Mixed Data Sampling (MIDAS) regression is an estimation technique which allows for data sampled at different frequencies to be used in the same regression. For MIDAS GARCH models, the goal is to incorporate information from a large number of lags of a lower frequency series into an ARCH regression; incorporating, for example, lags of quarterly data in a monthly data GARCH model.
EViews 14 estimates the multiplicative component MIDAS GARCH(1,1) model of Conrad and Kleen (2020), where the mean equation is given by
(27.42)
and the error variance is the product of a transitory GARCH component and a permanent component ,
(27.43)
where are explanatory variables, is a dummy variable indicating negative shocks, and are lags of lower frequency exogenous variables.
Notably,
• the transitory component is modeled as a GARCH(1, 1), with a restricted intercept term.
• the dummy variable and associated coefficient allow you to introduce asymmetry in the transitory component; if the component is symmetric.
• the permanent component is modeled using an intercept term and lags of with weights .
The underlying model is similar to the asymmetric Component GARCH(1,1) model (27.27). Here, the transitory and permanent variance components are multiplicative instead of additive, and the permanent component is modeled using the lower frequency variable lags.
Typically, researchers employ a full year of lags in modeling the permanent component so there may be a large number of parameters to be estimated, e.g., for a single monthly variable, and for a single weekly variable.
To reduce the number of parameters, we use a MIDAS weighting function to model the weights. Following Conrad and Kleen (2020), we employ a slightly modified version of the Ghysels, Santa-Clara and Valkanov (2004) beta function weighting scheme, where we parameterize the in terms of a slope parameter , and a small number of weights:
The beta weighting function is extremely flexible and can take many shapes, including gradually increasing or decreasing, flat, humped, or U-shaped, depending on the values of the three MIDAS parameters .
In practice, the parameters of the beta function are often further restricted by imposing a shape restriction (), an endpoint restriction (), or both restrictions ( and ) (see “Beta Weighting” for related discussion).
To estimate a MIDAS GARCH equation in EViews, the dated page with the high-frequency data must be active, and the lower-frequency data used to model the long-run component must be in a separate, low-frequency page.
Next, create an equation object by selecting Object/New Object.../Equation or Quick/Estimate Equation… from the main menu, or enter the keyword equation in the command window. Select ARCH - Autoregressive Conditional Heteroskedasticity in the Method drop-down menu. Alternately, entering the keyword arch in the command window will create a new equation object and automatically set the main estimation method.
EViews will display the base ARCH dialog. Change the Model drop down menu in the middle of the page to MIDAS to display the MIDAS GARCH Specification page:
There are three distinct sections in the Specification tab of the dialog.
• The Mean equation section contains settings for the specification of the mean. Enter the specification by list, providing the name of the dependent variable followed by any mean regressors.
The ARCH-m drop down menu may be used to determine whether to add a variance term to the mean equation. You may choose between adding None, Std. Dev., Variance, or Log(Var) to the specification.
• The Variance specification section contains settings for the variance equation.
The transitory variance for MIDAS models is a GARCH(1, 1). The Include threshold term checkbox may be used to include an asymmetric component in the transitory specification so that EViews will estimate Equation (27.42) with as a free parameter. If this option is not specified, EViews will enforce symmetry by setting .
The permanent component for MIDAS uses lags of a low frequency regressor. You should enter the name of a single permanent component regressor in the Low frequency regressor edit field. Note that EViews only allows the specification of a single low frequency regressor. The syntax for specifying this variable is pagename\seriesname where pagename is the name of the page containing the series, and seriesname is the name of the series. You should use the Lag edit field to specify the number of low frequency regressor lags to include in the permanent component.
• The Estimation settings section contains the usual drop down for estimation method and the sample specification.
Clicking on the Options page shows a variety of MIDAS GARCH options:
• The MIDAS weights section consists of a Beta Restriction drop down where you may specify restrictions on the parameters of the MIDAS beta weighting function. You may use the menu to choose None (no restrictions), Shape (a shape restriction where , Endpoint (an endpoint restriction where ), or Both (both shape and endpoint restrictions). See “Beta Weighting” for discussion.
• The Coefficient covariance section offers the standard choices coefficient covariance estimation methods.
• The Coefficient name edit field allows you to specify the name of a coefficient object to use in estimation.
• The Optimization section controls settings associated with estimation.
The top portion of the section offers the usual settings for estimating ARCH equations.
The Optimization method drop-down allows you to choose between BFGS, OPG-BHHH (Gauss-Newton-OPG), Newton-Raphson, and the default Hybrid optimization. The hybrid method is a combination of the OPG-BHHH and BFGS methods, where OPG is used for an initial 50 iterations, then BFGS is used until convergence. We have found that the hybrid method often reaches convergence more successfully than OPG or BFGS alone.
The Step method menu allow you to choose the approach for choosing candidate iterative steps. The default method is Marquardt, but you may instead select Dogleg or Line Search.
The estimation process achieves convergence if the stopping rule is reached using the tolerance specified in the Convergence Tolerance. Iterative estimation stops when the Maximum Iterations is reached, regardless of whether the convergence is achieved.
The remaining section controls starting values for the iterative estimation.
Baseline initial coefficient values are obtained by setting , , (if relevant), , , and , then performing OLS assuming those values to obtain starting values for .
The Starting coefficient values drop down menu allows you to specify EViews Supplied (the baseline starting values), fractions of the baseline values, Zero, User-specified (using the contents of the default coefficient vector in the workfile), or the default entry, Random. The Random method first uses the baseline starting values, then if convergence is not achieved, chooses random values for the coefficients until convergence is achieved, or until the Maximum random starts is reached. The are drawn from a Uniform(0, 1) distribution and the are drawn from a Uniform(-2, 2) distribution.
The randomization procedure is governed by the specified Random generator and the random Seed fields. You may provide an integer value from 0 to 2,147,483,647, or you may the leave the Seed field blank, in which case EViews will use the clock to obtain a seed at the time of estimation.
Representations
Coefficient Labels
Almost all of the views and procedures for a standard GARCH model work identically for a MIDAS GARCH equation. We offer brief comments on a couple of views.
Representations
The Representations view (View/Representations) offers text representations of the estimation command string, and the mean and variance equations.
The mean equation shows that RETURNS is simply equal to the intercept. The GARCH variance equation shows the multiplicative form of the equation using both the underlying coefficients and substituted values.
In contrast to most EViews Representations views, however, the MIDAS GARCH Representations view does not provide expressions that may be evaluated using the EViews. Notably, the equation for TAU is only a pseudo-representation of the permanent component specification. Thus, the TAU and GARCH equations may not be evaluated without additional modification.
Coefficient Labels
The coefficient label view makes it easy to map the results in the main estimation output to the underlying coefficient values. This is especially useful in allowing you to see the coefficients corresponding to the different variance components.
To see the coefficient label view, click on View/Coefficient Labels:
The view makes it easy to see that the long-run components for the estimator are C(4), C(5) and C(6).
In some cases, you might wish to estimate an ARCH model not mentioned above, for example a special variant of PARCH. Many other ARCH models can be estimated using the logl object. For example, “The Log Likelihood (LogL) Object” contains examples of using logl objects for simple bivariate GARCH models.
