Object Reference : Object View and Procedure Reference : Coef
label
Display or change the label view of the coefficient vector, including the last modified date and display name (if any).
As a procedure, label changes the fields in the coef object label.
coef_name.label
coef_name.label(options) text
To modify the label, you should specify one of the following options along with optional text. If there is no text provided, the specified field will be cleared:
c
Clears all text fields in the label.
d
Sets the description field to text.
s
Sets the source field to text.
u
Sets the units field to text.
r
Appends text to the remarks field as an additional line.
p
Print the label view.
The following lines replace the remarks field of the coefficient vector C1 with “Results from EQ3”:
c1.label(r)
c1.label(r) Results from EQ3
See “Labeling Objects” for a discussion of labels.
See also Coef::displayname.
