Test joint significance of the fixed effects estimates.
Tests the hypothesis that the estimated fixed effects are jointly significant using and LR test statistics. If the estimated specification involves two-way fixed effects, three separate tests will be performed; one for each set of effects, and one for the joint effects.
eq_name.fixedtest(options)
p
Print output from the test.
equation eq1.ls(cx=f) sales c adver lsales
eq1.fixedtest
estimates a specification with cross-section fixed effects and tests whether the fixed effects are jointly significant.
