rotate |
type=arg (default=“orthog”) | Orthogonal (“orthog”) or oblique (“oblique”) rotation (ignored if method is not supported, e.g, “orthogonal Harris-Kaiser” or “oblique Entropy Ratio”). |
method=arg (default=“varimax”) | Method (objective) for the rotation. See keywords below |
param=arg | Rotation parameter, if applicable (see description below). |
preparam=arg (default=1, Varimax) | Orthomax pre-rotation parameter (for “method=hk” and “method=promax”). |
Method | Keyword | Orthogonal | Oblique |
Biquartimax | biquartimax | • | • |
Crawford-Ferguson | cf | • | • |
Entropy | entropy | • | |
Entropy Ratio | entratio | • | |
Equamax | equamax | • | • |
Factor Parsimony | parsimony | • | • |
Generalized Crawford-Ferguson | gcf | • | • |
Geomin | geomin | • | • |
Harris-Kaiser (case II) | hk | • | |
Infomax | infomax | • | • |
Oblimax | oblimax | • | |
Oblimin | oblimin | • | |
Orthomax | orthomax | • | • |
Parsimax | parsimax | • | • |
Pattern Simplicity | pattern | • | • |
Promax | promax | • | |
Quartimax/Quartimin | quartimax | • | • |
Simplimax | simplimax | • | • |
Tandem I | tandemi | • | |
Tandem II | tandemii | • | |
Target | target | • | • |
Varimax | varimax | • | • |
is evaluated using the Crawford-Ferguson objective with factor complexity weight
(see
“Types of Rotation”).
), Varimax (
), Equamax (
), Parsimax (
) and Factor Parsimony (
).Method | ![]() | Parameter Description |
Crawford-Ferguson | 1 | Factor complexity weight. The variable complexity weight is 1 minus the factor complexity weight. (default=0, Quartimax) |
Generalized Crawford-Ferguson | 4 | Vector of weights for (in order): total squares, variable complexity, factor complexity, diagonal quartics. (no default) |
Geomin | 1 | Epsilon offset. (default=0.01) |
Harris-Kaiser (case II) | 2 | Power parameter (default=0, independent cluster solution), Orthomax pre-rotation parameter. (default=1, Varimax) |
Oblimin | 1 | Deviation from orthogonality. (default=0, Quartimin) |
Orthomax | 1 | Factor complexity weight. (default=1, Varimax) |
Promax | 2 | Power parameter (default=3), Orthomax pre-rotation parameter (default=1, Varimax). |
Simplimax | 1 | Fraction of near-zero loadings. (default=0.75) |
Target | 1 | Name of matrix of target loadings. Missing values correspond to unrestricted elements.(no default) |
is the number of variables and
is the number of factors. The remaining options modify the properties of the specified rotation method:wgts=arg (default=“none”) | Row weighting for loadings: none (“none”), kaiser (“kaiser”), Cureton-Mulaik (“cureton”). |
prior=arg (default =“unrotated”) | Initial rotation matrix: unrotated (“unrotated”), randomly generated (“random”), previous rotation (“previous”), user-specified (“user”). |
ptype=arg (default=“orthog”) | Type of prior random rotation: orthogonal (“orthog”) or oblique (“oblique”). Only relevant if “prior=random” and the main rotation method is oblique. If the main rotation method is orthogonal, random prior rotations will be orthogonalized. |
preps=integer (default=25) | Number of random prior rotations to evaluate (maximum 10000). |
pname=arg | Name of matrix containing prior rotation. |
pseed=positive integer | Seed the random number generator for the prior random rotations. If not specified, EViews will seed the random number generator with a single integer draw from the default global random number generator. |
Type of random number generator for the random prior rotation: improved Knuth generator (“kn”), improved Mersenne Twister (“mt”), Knuth’s (1997) lagged Fibonacci generator used in EViews 4 (“kn4”) L’Ecuyer’s (1999) combined multiple recursive generator (“le”), Matsumoto and Nishimura’s (1998) Mersenne Twister used in EViews 4 (“mt4”). | |
m=integer | Maximum number of iterations. |
c=scalar | Set convergence criterion. The criterion is based upon the norm of the gradients scaled by the objective function. The criterion will be set to the nearest value between 1e-24 and 0.2. |
showopts / ‑showopts | [Do / do not] display the starting coefficient values and estimation options in the rotation output. |
p | Print rotation results. |
