Command Reference : Function Reference : Function Reference: F
@floor
Largest integer less than or equal to (with optional precision).
Syntax: @floor(x[, n])
x: number
n: (optional) integer
Return: number
• @floor(x) returns , the largest integer that is less than or equal to x.
• @floor(x, n) returns , the largest decimal number that is less than or equal to x at the given precision.
The decimal offset n may be interpreted as the precision to use when computing the floor. If n is not an integer, the integer floor will be used.
= @floor(@pi)
returns 3.
= @floor(@pi,2)
returns 3.14.
= @floor(-@pi)
returns -4.
See also @ceil.
