options |
legend / -legend | Turn on and off legend. |
size(w, h) | Specifies the size of the plotting frame in virtual inches (w=width, h=height). |
lineauto | Use solid lines when drawing in color and use patterns and grayscale when drawing in black and white. |
linesolid | Always use solid lines. |
linepat | Always use line patterns. |
color / -color | Specifies that lines/filled areas [use / do not use] color. Note that if the “lineauto” option is specified, this choice will also influence the type of line or filled area drawn on screen: if color is specified, solid colored lines and filled areas will be drawn; if color is turned off, lines will be drawn using black and white line patterns, and gray scales will be used for filled areas. |
barlabelabove / -barlabelabove | [Place / Do not place] text value of data above bar in bar graph. |
barlabelinside barlabelinside | [Place / Do not place] text value of data inside bar in bar graph. |
barlabelnone | Remove text value of data from bar graph. |
outlinebars / -outlinebars | [Outline / Do not outline] bars in a bar graph. |
outlinearea / -outlinearea | [Outline / Do not outline] areas in an area graph. |
outlineband / -outlineband | [Outline / Do not outline] bands in an area band graph. |
barspace /‑barspace | [Put / Do not put] space between bars in bar graph. |
pielabel / -pielabel | [Place / Do not place] text value of data in pie chart. |
automult/-automult | [Auto reduce / Do not autoreduce] frame size in multiple graphs to make text appear larger |
dual/-dual | [Overlap / Do not overlap] scales (no cross). |
barfade(arg) | Sets the fill fade of the bars in a bar graph. arg may be: “none” (solid fill - default), “3d” (3D rounded fill), “lzero” (light at zero), “dzero” (dark at zero). |
antialias(arg) | Sets anti-aliasing to smooth the appearance of data lines in the graph. arg may be: “auto” (EViews uses anti-aliasing where appropriate - default), “on”, or “off”. |
interpolate(arg) | Sets the interpolation method to estimate values between two known data points in the graph. arg may be: “linear” (no interpolation), “mild” (mild spline), “medium” (medium spline), or “full” (full spline). |
stackposneg / ‑stackposneg | For bar graphs, stack positive and negative values separately (Excel style). |
gridl / -gridl | [Turn on / Turn off] grid lines on the left scale. |
gridr / -gridr | [Turn on / Turn off] grid lines on the right scale. |
gridb / -gridb | [Turn on / Turn off] grid lines on the bottom scale. |
gridt / -gridt | [Turn on / Turn off] grid lines on the top scale. |
gridnone | No grid lines (turns of time scale grid). |
gridauto | Allow EViews to place grid lines at automatic intervals. |
gridcust(freq [,step]) | Place grid lines at custom intervals, specified by freq. freq may be: “obs” or “o” (Step = One obs), “year” or “y” (Step = Year), “quarter” or “q” (Step = Quarter), “month” or “m” (Step = Month), “day” or “d” (Step = Day), “user” or “u” (Step = custom). You may optionally specify a step for the interval. If not specified, the default is the last grid step used for this graph, or 1 if a step has never been specified. |
gridcolor(arg) | Sets the grid line color. arg may be one of the predefined color keywords, or it may be specified using individual red-green-blue (RGB) components using the “@RGB” or “@HEX” functions. The arguments to the @RGB function are a set of three integers from 0 to 255, representing the RGB values of the color. The arguments to the “@HEX” function are a set of six characters representing the RGB values of the color in hexadecimal. Each two character set represents a red, green or blue component in the range '00' to 'FF'. For a description of the available color keywords see
“Color definitions”. |
gridwidth(n) | Sets the width of the grid lines in points. n should be a number between 0.25 and 5. |
gridpat(index) | Sets the default line pattern to the type specified by index. index can be an integer from 1 to 12 or one of the matching keywords (“solid”, “dash1” through “dash10”, “none”). Sets the line pattern to the type specified by index. index can be an integer from 1 to 12 or one of the matching keywords (“solid”, “dash1” through “dash10”, “none”). ![]() The “none” keyword turns on solid lines. |
gridontop / -gridontop | [Draw / Do not draw] the grid lines on top of the graph. |
fillcolor(arg) | Sets the fill color of the graph frame. arg may be one of the predefined color keywords, or it may be specified using individual red-green-blue (RGB) components using the “@RGB” or “@HEX” functions. The arguments to the @RGB function are a set of three integers from 0 to 255, representing the RGB values of the color. The arguments to the “@HEX” function are a set of six characters representing the RGB values of the color in hexadecimal. Each two character set represents a red, green or blue component in the range '00' to 'FF'. For a description of the available color keywords see
backcolor(arg) | Sets the background color of the graph. arg may be one of the predefined color keywords, or it may be specified using individual red-green-blue (RGB) components using the “@RGB” or “@HEX” functions. The arguments to the @RGB function are a set of three integers from 0 to 255, representing the RGB values of the color. The arguments to the “@HEX” function are a set of six characters representing the RGB values of the color in hexadecimal. Each two character set represents a red, green or blue component in the range '00' to 'FF'. For a description of the available color keywords see
framecolor(arg) | Sets the background color of the graph frame. arg may be one of the predefined color keywords, or it may be specified using individual red-green-blue (RGB) components using the “@RGB” or “@HEX” functions. The arguments to the @RGB function are a set of three integers from 0 to 255, representing the RGB values of the color. The arguments to the “@HEX” function are a set of six characters representing the RGB values of the color in hexadecimal. Each two character set represents a red, green or blue component in the range '00' to 'FF'. For a description of the available color keywords see
“Color definitions”.. |
fillfade(arg) | Sets the fill fade of the graph frame. arg may be: “none” (solid frame fill - default), “ltop” (light at top), “dtop” (dark at top). |
backfade(arg) | Sets the background fade of the graph. arg may be: “none” (solid background - default), “ltop” (light at top), “dtop” (dark at top). |
framewidth(n) | Sets the width of the graph frame in points. n should be a number between 0.25 and 5. |
frameaxes(arg) | Specifies which frame axes to display. arg may be one of the keywords: “all”, “none”, or “labeled” (all axes that have labels), or any combination of letters “l” (left), “r” (right), “t” (top), and “b” (bottom), e.g. “lrt” for left, right and top. |
indenth(n) | Sets the horizontal indentation of the graph from the graph frame in virtual inches. n should be a number between 0 and 0.75. |
indentv(n) | Sets the vertical indentation of the graph from the graph frame in virtual inches. n should be a number between 0 and 0.75. |
inbox / -inbox | [Show / Do not show] the graph frame on axes that do not have data assigned to them. |
background / ‑background | [Include / Do not include] the background color when exporting or printing the graph. |
drop (default) | For a graph with a non-contiguous sample, drop the excluded observations from the graph scale. |
connect | For a graph with missing values or a non-contiguous sample, connect non-missing observations. |
disconnect | For a graph with missing values or a non-contiguous sample, disconnect non-missing observations. |
pad | For a graph with a non-contiguous sample, pad the graph scale with the excluded observations |
segment | For a graph with a non-contiguous sample, drop the excluded observations from the graph scale and draw vertical lines at the seams in the observation scale. |
blue | @rgb(0, 0, 255) | @hex(0000ff) |
red | @rgb(255, 0, 0) | @hex(ff0000) |
ltred | @rgb(255, 168, 168) | @hex(ffa8a8) |
green | @rgb(0, 128, 0) | @hex(008000) |
black | @rgb(0, 0, 0) | @hex(000000) |
white | @rgb(255, 255, 255) | @hex(ffffff) |
purple | @rgb(128, 0, 128) | @hex(800080) |
orange | @rgb(255, 128, 0) | @hex(ff8000) |
yellow | @rgb(255, 255, 0) | @hex(ffff00) |
gray | @rgb(128, 128, 128) | @hex(808080) |
ltgray | @rgb(192, 192, 192) | @hex(c0c0c0) |
frame enclosed in a box. The graph will use color.
frame with no box. The graph does not use color, with the lines instead being displayed using patterns.
