dimensional time series vector process
, with cointegrating equation![]() | (28.1) |
are deterministic trend regressors and the
stochastic regressors
are governed by the system of equations:![]() | (28.2) |
-vector of
regressors enter into both the cointegrating equation and the regressors equations, while the
-vector of
are deterministic trend regressors which are included in the regressors equations but excluded from the cointegrating equation (if a non-trending regressor such as the constant is present, it is assumed to be an element of
so it is not in
are strictly stationary and ergodic with zero mean, contemporaneous covariance matrix
, one-sided long-run covariance matrix
, and covariance matrix
, each of which we partition conformably with
![]() | (28.3) |
with non-singular sub-matrix
. Taken together, the assumptions imply that the elements of
and
are I(1) and cointegrated but exclude both cointegration amongst the elements of
and multicointegration. Discussions of additional and in some cases alternate assumptions for this specification are provided by Phillips and Hansen (1990), Hansen (1992b), and Park (1992).
in
Equation (28.1) is consistent, converging at a faster rate than is standard (Hamilton 1994). One important shortcoming of static OLS (SOLS) is that the estimates have an asymptotic distribution that is generally non-Gaussian, exhibit asymptotic bias, asymmetry, and are a function of non-scalar nuisance parameters. Since conventional testing procedures are not valid unless modified substantially, SOLS is generally not recommended if one wishes to conduct inference on the cointegrating vector.
, and cross-correlation between the cointegrating equation errors and the regressors
. In the special case where the
are strictly exogenous regressors so that
and
, the bias, asymmetry, and dependence on non-scalar nuisance parameters vanish, and the SOLS estimator has a fully efficient asymptotic Gaussian mixture distribution which permits standard Wald testing using conventional limiting
-distributions.
is no less than the number of stochastic regressors
. Let
represent the number of cointegrating regressors less the number of deterministic trend regressors excluded from the cointegrating equation. Then, roughly speaking, when
, the deterministic trends in the regressors asymptotically dominate the stochastic trend components in the cointegrating equation.
case.
