edftest |
dist=arg (default=”nomal”) | Distribution to test: “normal” (Normal distribution), “chisq” (Chi-square distribution), “exp” (Exponential distribution), “xmax” (Extreme Value - Type I maximum), “xmin” (Extreme Value Type I minimum), “gamma” (Gamma), “logit” (Logistic), “pareto” (Pareto), “uniform” (Uniform). |
p1=number | Specify the value of the first parameter of the distribution (as it appears in the dialog). If this option is not specified, the first parameter will be estimated. |
p2=number | Specify the value of the second parameter of the distribution (as it appears in the dialog). If this option is not specified, the second parameter will be estimated. |
p3=number | Specify the value of the third parameter of the distribution (as it appears in the dialog). If this option is not specified, the third parameter will be estimated. |
p | Print test results. |
b | Use Berndt-Hall-Hall-Hausman (BHHH) algorithm. The default is Marquardt. |
m=integer | Maximum number of iterations. |
c=number | Set convergence criterion. The criterion is based upon the maximum of the percentage changes in the scaled coefficients. |
showopts / ‑showopts | [Do / do not] display the starting coefficient values and estimation options in the estimation output. |
s | Take starting values from the C coefficient vector. By default, EViews uses distribution specific starting values that typically are based on the method of the moments. |
distribution with degrees-of-freedom estimated from the data.
distribution with 5 degrees of freedom. The output is stored as a table object TAB1.
