outliers |
hp | Perform the Hodrick-Prescott filter on the series, and then detect outliers on the cycle series. |
diff | First-difference the series before detecting outliers. |
sens=arg | Set the sensitivity level. Valid arguments are “low”, “medium” (default), and “high”. |
nofence | Do not perform Tukey and mean/standard deviation fences. |
nowave | Do not perform Wavelet Outlier detection. |
arma | Perform ARMA based outlier detection (this option is turned on by default in dated workfiles). |
noarma | Do not perform ARMA based outlier detection (this option is turned on by default in undated workfiles). |
tukeyk=arg | Set the value k in the Tukey fence detection routine. This will override the value of k set by the sens= option. |
meanstdevk=arg | Set the value k in the mean/standard deviation fence detection routine. This will override the value of k set by the sens= option. |
wavesig=arg | Set the value false discovery rate significance value used in the Wavelet Outlier detection routine. This will override the value set by the sens= option. |
armac=arg | Set the value c in the ARMA outlier detection routine. This will override the value of c set by the sens= option. |
setsmpl | Set the workfile sample to be any observations identified as outliers. |
excludesmpl | Set the workfile sample to be any observations identified as not outliers. |
series=name | Create a new series in the workfile, named name, containing a value of 1 for any observations identified as an outlier, and a value of 0 for any observation identified as not an outlier. |
datestring=name | Create a new string object in the workfile containing the dates (or observation identifiers) for any observations identified as an outlier. |
nogrlabels | Turn off observation labels on the outlier graph. |
p | Print results. |
