seasuroot |
type = arg (default= “hegy”) | Test type: HEGY (“hegy”), HEGY likelihood (“lklhd”), Canova-Hansen (“ch”), HEGY variance ratio (“hegyvr”). |
out= arg | Output matrix name (optional). |
periods = arg | Periodicity: “2”, “4”, “5”, “6”, or “12”. The default is workfile frequency specific: semi-annual (2), quarterly (4), bi-monthly (6), monthly (12), all others (4). |
rstrct =arg | Restrictions to test (if “test=ch”): arg = space separated list of integers, “all” (all frequencies). For example, if the number of periods is 4, the restriction “0 1 2” corresponds to the 0, harmonic pair , and frequencies. |
dtr = arg | Non-seasonal deterministic variables to include in estimation: “none” (no exogenous variables), “const” (constant), “trend” (constant and linear trend). The default is “const” for “type=hegyvr” and “none” for all others. |
sdtr = arg | Seasonal deterministic variables to include in estimation: “none” (no seasonal exogenous), “dum” (seasonal dummies), “const” (constant), “trend” (constant and linear trend). |
lagdep | Include lag of dependent variable in computations for Canova-Hansen test (“type = ch”). |
lagmethod=arg (default=“sic”) | Method for selecting lag lengths (number of first difference terms) to be included in the Dickey-Fuller test regressions: “aic” (Akaike), “sic” (Schwarz), “hqc” (Hannan-Quinn), “tstat” (Ng-Perron first backward significant t-statistic). |
lag=arg | Specified lag length (number of first difference terms) to be included in the regression: integer (user-specified common lag length), vector_name (user-specific individual lag length, one row per cross-section). |
maxlag=arg | Maximum lag length to consider when performing automatic lag length selection: integer (common maximum lag length), or vector_name (individual maximum lag length, one row per cross-section). The default setting produces individual maximum lags of, default= ![]() where is the length of the cross-section. |
lagpval=arg (default=0.1) | Probability value for use in the t-statistic automatic lag selection method (when “lagmethod = tstat”). |
p | Print output from the test. |
