Object Reference : Object View and Procedure Reference : Spool
append
Append objects to a spool.
spool_name.append(options) object_list
where object_list is a list of one or more objects to be appended to the spool. You may specify a view for each object, otherwise the default view will be used.
name=arg
Set the names of the objects in the spool. arg is a space delimited list of new names for the list of objects being added to the spool. If this option is omitted, the names will be UNTITLED01, UNTITLED02, etc.
mode=overwrite
Will remove any existing objects with the same name when used in conjunction with the name=arg option.
To insert a line graph view of series SER1 and a bar graph view of SER2 as the last objects in SPOOL01:
spool01.append ser1.line ser2.bar
To replace a preexisting object X in SPOOL01 with the line graph view of series SER1:
spool01.append(name=X, mode=overwrite) ser1.line
For additional discussion of spools see “Spool Objects”. See also Spool::insert and Spool::remove.
