cor |
cov | Product moment covariance. |
corr | Product moment correlation. |
sscp | Sums-of-squared cross-products. |
stat | Test statistic (t-statistic) for evaluating whether the correlation is zero. |
prob | Probability under the null for the test statistic. |
cases | Number of cases. |
obs | Number of observations. |
wgts | Sum of the weights. |
rcov | Spearman’s rank covariance. |
rcorr | Spearman’s rank correlation. |
rsscp | Sums-of-squared cross-products. |
rstat | Test statistic (t-statistic) for evaluating whether the correlation is zero. |
rprob | Probability under the null for the test statistic. |
taub | Kendall’s tau-b. |
taua | Kendall’s tau-a. |
taucd | Kendall’s concordances and discordances. |
taustat | Kendall’s score statistic for evaluating whether the Kendall’s tau-b measure is zero. |
tauprob | Probability under the null for the score statistic. |
ucov | Product moment covariance. |
ucorr | Product moment correlation. |
usscp | Sums-of-squared cross-products. |
ustat | Test statistic (t-statistic) for evaluating whether the correlation is zero. |
uprob | Probability under the null for the test statistic. |
wgt=name (optional) | Name of vector containing weights. The number of rows of the weight vector should match the number of rows in the original matrix. |
wgtmethod=arg (default = “sstdev”) | Weighting method (when weights are specified using “weight=”): frequency (“freq”), inverse of variances (“var”), inverse of standard deviation (“stdev”), scaled inverse of variances (“svar”), scaled inverse of standard deviations (“sstdev”). Only applicable for ordinary (Pearson) calculations. Weights specified by “wgt=” are frequency weights for rank correlation and Kendall’s tau calculations. |
pairwise | Compute using pairwise deletion of observations with missing cases (pairwise samples). |
df | Compute covariances with a degree-of-freedom correction to account for estimated means (for centered specifications), and any partial conditioning variables. |
multi=arg (default=“none”) | Adjustment to p-values for multiple comparisons: none (“none”), Bonferroni (“bonferroni”), Dunn-Sidak (“dunn”). |
outfmt=arg (default= “single”) | Output format: single table (“single”), multiple table (“mult”), list (“list”), spreadsheet (“sheet”). Note that “outfmt=sheet” is only applicable if you specify a single statistic keyword. |
out=name | Basename for saving output. All results will be saved in Sym matrices named using keys (“COV”, “CORR”, “SSCP”, “TAUA”, “TAUB”, “CONC” (Kendall’s concurrences), “DISC” (Kendall’s discordances), “CASES”, “OBS”, “WGTS”) appended to the basename (e.g., the covariance specified by “out=my” is saved in the Sym matrix “MYCOV”). |
p | Print the result. |
Pearson correlation matrix for the columns series in MAT1.
