Sym
Symmetric matrix (symmetric two-dimensional array).
Sym Declaration
Declare by providing a name after the sym keyword, with the optionally specified dimension in parentheses:
sym(10) symmatrix
You may optionally assign a scalar, a square matrix or another sym in the declaration. If the square matrix is not symmetric, the sym will contain the lower triangle. The sym will be sized and initialized accordingly.
Sym Views
cor correlation matrix by columns.
cov covariance matrix by columns.
eigen eigenvalues calculation for a symmetric matrix.
label label information for the symmetric matrix.
sheet spreadsheet view of the symmetric matrix.
stats descriptive statistics by column.
Sym Procs
copy creates a copy of the sym.
export save sym matrix as Excel 2007 XLSX, CSV, tab-delimited ASCII text, RTF, HTML, Enhanced Metafile, PDF, TEX, or MD file on disk.
fill fill the elements of the matrix.
import imports data from a foreign file into the sym object.
olepush push updates to OLE linked objects in open applications.
read (deprecated) import data from disk.
setattr set the value of an object attribute.
setformat set the display format for the sym spreadsheet.
setindent set the indentation for the sym spreadsheet.
setjust set the horizontal justification for all cells in the spreadsheet view of the sym object.
setwidth set the column width in the sym spreadsheet.
showlabels displays the custom row and column labels of a sym spreadsheet.
write export data to disk.
Sym Graph Views
Graph creation views are discussed in detail in
“Graph Creation Command Summary”.
area area graph of the columns of the matrix.
bar bar graph of each column against the row index.
hilo high-low(-open-close) chart.
line line graph of each column against the row index.
qqplot quantile-quantile graph.
scat scatter diagrams of the columns of the sym.
scatmat matrix of all pairwise scatter plots.
Sym Data Members
String values
@attr("arg") string containing the value of the arg attribute, where the argument is specified as a quoted string.
@collabels string containing the column labels of the sym.
@description string containing the Sym object’s description (if available).
@detailedtype string with the object type: “SCALAR”.
@displayname string containing the Sym object’s display name. If the Sym has no display name set, the name is returned.
@name string containing the Sym object’s name.
@remarks string containing the Sym object’s remarks (if available).
@rowlabels string containing the row labels of the sym.
@type string with the object type: “SCALAR”.
@updatetime string representation of the time and date at which the Sym was last updated.
Scalar values
(i,j) (i,j)-th element of the sym. Simply append “(i,j)” to the sym name (without a “.”).
@cols number of columns in the sym.
@rows number of rows in the sym.
Matrix values
@col(arg) Returns the columns defined by arg. arg may be an integer, vector of integers, string, or svector of strings. Integers correspond to column numbers so that, for example, arg = 2 specifies the second column. Strings correspond to column labels so that arg = "2" specifies the first column labeled “2”.
@diag vector containing the diagonal elements of the sym.
@drop(arg) Returns the sym with the rows and columns defined by arg removed. arg may be an integer, vector of integers, string, or svector of strings. Integers correspond to row and column numbers so that, for example, arg = 2 specifies the second row and column. Strings correspond to row and column labels so that arg = "2" specifies the first row and column labeled “2”.
@dropboth(arg1, arg2) Returns the matrix with the rows defined by arg1 and columns defined by arg2 removed. The args may be integers, vectors of integers, strings, or svectors of strings. Integers correspond to row or column numbers so that, for example, arg1 = 2 specifies the second row. Strings correspond to row or column labels so that arg2 = "2" specifies the first column labeled “2”.
@dropcol(arg) Returns the matrix with the columns defined by arg removed. arg may be an integer, vector of integers, string, or svector of strings. Integers correspond to column numbers so that, for example, arg = 2 specifies the second column. Strings correspond to column labels so that arg = "2" specifies the first column labeled “2”.
@droprow(arg) Returns the matrix with rows defined by arg removed. arg may be an integer, vector of integers, string, or svector of strings. Integers correspond to row numbers so that, for example, arg = 2 specifies the second row. Strings correspond to row labels so that arg = "2" specifies the first row labeled “2”.
@row(arg) Returns the rows defined by arg. arg may be an integer, vector of integers, string, or svector of strings. Integers correspond to row numbers so that, for example, arg = 2 specifies the second row. Strings correspond to row labels so that arg = "2" specifies the first row labeled “2”.
@sub(arg) Returns the sym with rows and columns defined by arg. arg may be an integer, vector of integers, string, or svector of strings. Integers correspond to row and column numbers so that, for example, arg = 2 specifies the second row and column. Strings correspond to row and column labels so that arg = "2" specifies the first row and column labeled “2”.
@sub(arg1, arg2) Returns the matrix with rows defined by arg1 and columns defined by arg2. The args may be integers, vectors of integers, strings, or svectors of strings. Integers correspond to row or column numbers so that, for example, arg1 = 2 specifies the second row. Strings correspond to row or column labels so that arg2 = "2" specifies the first column labeled “2”.
@t Returns transpose (copy) of the sym.
Sym Examples
The declaration:
sym results(10)
results=3
creates the
matrix
RESULTS and initializes each value to be 3. The following assignment statements also create and initialize sym objects:
sym copymat=results
sym covmat1=eq1.@coefcov
sym(3,3) count
count.fill 1,2,3,4,5,6,7,8,9,10
Graphs, covariances, and statistics may be generated for the columns of the matrix:
copymat.line
copymat.cov
copymat.stats
You can use explicit indices to refer to matrix elements:
scalar diagsum=cov1(1,1)+cov1(2,2)+cov(3,3)
