area |
Command ||
Coef View |
Graph Command |
Group View |
Matrix View |
Series View |
Sym View |
Vector View |
a (default) | Automatic single scale. |
d | Dual scaling with no crossing. The first series or column is scaled on the left and all other series or columns are scaled on the right. |
x | Dual scaling with possible crossing. See the “d” option. |
n | Normalized scale (zero mean and unit standard deviation). May not be used with the “s” option. |
rotate | Rotate the graph so the observation axis is on the left. |
ab=type | Add axis border along data scale, where type may be “hist” or “h” (histogram), “boxplot” or “b”, “kernel” or “k”. (Note: axis borders are not available for panel graphs with “panel=” options that involve summaries: mean, median, etc.) |
m | Plot areas in multiple graphs (will override the “s” option). |
s | Stacked area graph. Each area represents the cumulative total of the series listed. The difference between areas corresponds to the value of a series. |
o=template | Use appearance options from the specified template. template may be a predefined template keyword (“default” - current global defaults, “classic”, “modern”, “reverse”, “midnight”, “spartan”, “monochrome”) or a graph in the workfile. |
t=graph_name | Use appearance options and copy text and shading from the specified graph. |
b / -b | [Apply / Remove] bold modifiers of the base template style specified using the “o=” option above. |
w / -w | [Apply / Remove] wide modifiers of the base template style specified using the “o=” option above. |
reset | Resets all graph options to the global defaults. May be used to remove existing customization of the graph. |
p | Print the graph. |
contract=key | Contract the data as specified by key, where key may be: “mean”, “median”, “max”, “min”, “sum”, “var” - variance, “sd” - standard deviation, “sumsq” - sum of the squared values, “skew” - skewness, “kurt” - kurtosis, “nas” - number of missing values, “obs” - number of observations, “unique” - error if the series is not identical for all observations in a given group, “first” - first observation in category using workfile order, “last” - last observation in category using workfile order, “quant(quantile)” - where quantile is a number between 0 and 1. |
panel=arg (default taken from global settings) | Panel data display: “stack” (stack the cross-sections), “individual” or “i” (separate graph for each cross-section), “combine” or “c” (combine cross-section graphs in a single frame), “mean” (plot means across cross-sections), “median” (plot median across cross-sections). (Note: more general versions of these panel graphs may be constructed as categorical graphs.) |
favorlegend | Favor the use of legends over axis labels to describe categories. |
elemcommon = int | Specifies the number of within factors for which the graph uses common area colors. For example, with multiple within dimensions, if “elemcommon=1”, then only categories defined by the first within factor will have common colors. If “elemcommon=2”, then categories defined by the first two within factors will have common colors. If “elemcommon=0”, all areas will have different colors. The default is one less than the number of within factors. |
