graph |
area | Area graph (
area). |
band | Area band graph (
band). |
bar | Bar graph (
bar). |
boxplot | Boxplot graph (
boxplot). |
distplot | Distribution graph (
distplot). |
dot | Dot plot graph (
dot). |
errbar | Error bar graph (
errbar). |
hilo | High-low(-open-close) graph (
hilo). |
line | Line graph (
line). |
pie | Pie graph (
pie). |
qqplot | Quantile-Quantile graph (
qqplot). |
scat | Scatterplot—same as XY, but lines are initially turned off, symbols turned on, and a frame is used (
scat). |
scatmat | Matrix of scatterplots (
scatmat). |
scatpair | Scatterplot pairs graph (
scatpair). |
seasplot | Seasonal line graph (
seasplot). |
spike | Spike graph (
spike). |
xyarea | XY line-symbol graph with one X plotted against one or more Y’s using existing line-symbol settings (
xyarea). |
xybar | XY line-symbol graph with one X plotted against one or more Y’s using existing line-symbol settings (
xybar). |
xyline | Same as XY, but symbols are initially turned off, lines turned on, and a frame is used (
xyline). |
xypair | Same as XY but sets XY settings to display pairs of X and Y plotted against each other (
xypair). |
reset | Resets all graph options to the global defaults. May be used to remove existing customization of the graph. |
p | Print the graph (for use when specified with a graph command). |
