btvcvar |
T0 = int (default = 0) | Set prior sample size ![]() |
tau0 = num (default = 5.0) | Set prior scaling parameter for the initial state ![]() |
tau1 = num (default = 1.0) | Set prior scaling parameter for the observation covariance ![]() |
nu1 = num (default = 5.0) | Set prior dof parameter for the observation covariance ![]() |
tau2 = num (default = 0.01) | Set prior scaling parameter for the process covariance ![]() |
nu2 = num (default = 5.0) | Set prior dof parameter for the process covariance ![]() |
usemean | Use posterior mean as the point estimate. The posterior median is used if usemean is not included in the options list. |
showci | Show credibility intervals (bands). |
cilevels = arg (default = "0.95") | Set credibility levels. For multiple levels, enter a space-delimited list of values surrounded by quotation marks, e.g., "0.3 0.5 0.8". |
uselines | Use lines instead of shading for credibility intervals. |
burn = int (default = 5000) | Set burn-in size. |
size = int (default = 5000) | Set posterior sample size. |
thin = int (default = 1) | Set thinning size. A thinning size of ![]() ![]() |
nsub = int | Set the number of subchains. |
seed = int | Set the random seed. EViews will generate a seed if one is not specified. |
rng = arg (default = “kn” or method set via rndseed) | Set random number generator type. Available types are: improved Knuth generator (“kn”), improved Mersenne Twister (“mt”), Knuth’s (1997) lagged Fibonacci generator used in EViews 4 (“kn4”), L’Ecuyer’s (1999) combined multiple recursive generator (“le”), Matsumoto and Nishimura’s (1998) Mersenne Twister used in EViews 4 (“mt4”). |
smoother = arg (default = "CFA") | Set simulation smoothing method. Available methods are "CFA" (Cholesky factor algorithm), "KFS" (Kalman filter and smoother), and "MMP" (McCausland, Miller, & Pelletier, 2011). |
stable | Use the method of Cogley & Sargent for obtaining stable draws. |
maxattempts = int (default = 100) | Set the maximum number of attempts for the sampler to draw stable VAR coefficients for all dates in the data sample. |
noconst | Do not include a constant in the exogenous regressors list. |
