VAR lag order selection criteria.
var_name.laglen(m, options)
You must specify the maximum lag order m for which you wish to test.
vname=arg | Save selected lag orders in named vector. See below for a description of the stored vector. |
mname=arg | Save lag order criteria in named matrix. See below for a description of the stored matrix. |
p | Print table of lag order criteria. |
The “vname=” option stores a vector with 5 rows containing the selected lags from the following criteria: sequential modified LR test (row 1), final prediction error (row 2), Akaike information criterion (row 3), Schwarz information criterion (row 4), Hannan-Quinn information criterion (row 5).
The “mname=” option stores a
matrix, where
if there are no exogenous variables in the VAR; otherwise
. The first
rows contain the information displayed in the table view, following the same order. The saved matrix has an additional row which contains the lag order selected from each column criterion. The first column (corresponding to the log likelihood values) of the last row is always an NA.
var var1.ls 1 6 lgdp lm1 lcpi
show var1.laglen(12,vname=v1)
The first line declares and estimates a VAR. The second line computes the lag length criteria up to a maximum of 12 lags and stores the selected lag orders in a vector named V1.
See
“Vector Autoregression (VAR) Models” for a discussion of the various criteria and other VAR diagnostics.
