User’s Guide : Multiple Equation Analysis : Vector Error Correction Models (VECMs) : Background
Background
Cointegration
The VECM Specification
The Basic VECM
Basic VECM Estimation
VECMs with Deterministics
The Classical Approach
The Johansen, Hendry, and Juselius Approach
Estimating VECM with Deterministics
Popular VECM Deterministic Assumptions
Exogenous Variables in VECMs
Cointegration
An understanding of VECMs requires a discussion of the notion of system-wide integration and equilibrium. Some important definitions will set the stage for our discussion:
An individual time series is said to be integrated of order , , if is stationary, or , while is non-stationary.
A system of time series is said to be integrated of order , , if at least one of its constituent series is , and no series is for . Note that this definition does not preclude a subset of the system series from being of lower order (or even stationary).
An system is said to be cointegrated if a linear combination of the constituent series is integrated of (lower) order, where . Further, a system that is integrated of order is said to be cointegrated of order if there exists a cointegrating -vector such that . Notice that is not unique since multiplication by any nonzero constant yields a different cointegrating vector.
To simplify the following discussion, we will, without loss of generality, restrict to 1 and to 0 so that and .
The concept of cointegration introduced above is closely related to the notion of economic equilibrium. While individual economic processes may have volatile paths of evolution, there may be global forces which eventually produce stable paths of evolution. In particular, a group of economic variables may individually be , or non-stationary, but there may exist cointegrated processes (linear combinations) which are , or stationary. In this case, the cointegrated process is mean-reverting so that it while it may deviate from its expected value in the short-run, it eventually settles at its long-run (asymptotic) expected value.
The Basic VECM
When , the traditional levels-form VAR process is not the most useful representation since both the number and explicit form of any cointegrating relations are not easily obtained from this specification. Consequently, when analyzing cointegrating relationships we typically work with the VECM representation of the process.
The Basic VECM
Consider a VAR process of order :
(45.1)
where is a -vector of endogenous variables, are matrices of coefficients, and the residual vector is distributed with mean 0 and variance matrix . Note that for simplicity, we assume that there are no deterministic terms in the VAR. This restriction is relaxed in the discussion of “VECMs with Deterministics”.
The stability of the system is determined by the solutions to the determinant of the characteristic polynomial,
(45.2)
The process is said to be stable if the roots of the polynomial lie outside the complex unit circle, or have modulus greater than 1.
Note that when at least one constituent series is , the VAR process is unstable since we may show that
(45.3)
is singular, , and Equation (45.2) is satisfied for roots lying on the unit circle.
In general, plays a key role in identifying both the number and nature of any cointegrating relationships. To better understand this role, we subtract from both sides of the VAR representation Equation (45.1) and rearrange terms to obtain the VECM representation:
(45.4)
where
(45.5)
for .
To obtain this representation, we first take the VAR representation and subtract off the lag of the endogenous variables from both sides:
(45.6)
Next, we reparameterize the model by rewriting the remaining elements of the right-hand side as differences. Rewriting with the last two elements of the expression, we have
where
(45.7)
Similarly, we may transform the last two non-difference terms in this new expression. Focusing on just those two terms, we have
(45.8)
Define
(45.9)
Then we may rewrite the term as a difference using
(45.10)
Notice that this process of rewriting the last two non-difference terms forms a recursion. For the remaining non-difference pairs, we may write,
(45.11)
for . Substituting recursion Equation (45.11) into Equation (45.6), we have:
(45.12)
Then, using the initial value from Equation (45.7) and the recursion Equation (45.9), we have
(45.13)
Note that we may recover the parameters of the VAR from the parameters of the VECM using the relations
(45.14)
for .
To see the central role of in cointegration analysis, we focus on , the matrix rank of , where .
Since our discussion assumes that is , it follows that , and the are for all . There are two important implications of these conditions. First, since , it follows that has reduced rank (). Second, since the are all , to balance the order of both sides of Equation (45.4), must also be .
For any , there exist matrices and each of rank , such that
(45.15)
where is the transpose operator. Then we may write
(45.16)
and given our assumptions, must be an linear combination of the series in the system, with representing the cointegrating rank, and the cointegrating matrix. is typically referred to as the loading matrix.
Note that although is not unique, a suitable normalization is possible by rearranging the variables so that the first rows of the matrix are linearly independent:
(45.17)
where is a matrix. See Lütkepohl (2005) for details.
Lastly if , balancing both sides of Equation (45.6) requires . In this case we say that there are no cointegrating relations since no linear combinations of are .
While there are several methods for estimation of VECMs, we focus on the maximum likelihood (ML) variant, also known as reduced rank regression (RRR) (see Johansen (1995) and Lütkepohl (2005) for a detailed exposition).
Formally, RRR assumes a known cointegration rank , Gaussian innovation vectors , a time dimension of length , and is best described using the VECM matrix representation ( Equation (45.4)):
(45.18)
where
(45.19)
The RRR estimator is then the maximizer of the log-likelihood objective function:
(45.20)
Johanson (1995) shows that optimizing the likelihood is equivalent to solving the eigenvalue problem
(45.21)
under the constraint , where are the eigenvalues associated with eigenvector matrix , and
(45.22)
Solving the constrained eigenvalue problem yields that are the eigenvalues of the symmetric matrix
(45.23)
In terms of computation, note that and are the residuals from regression of the and on the . Further, may be obtained by first diagonalizing using the solution to the auxiliary eigenvalue problem
(45.24)
to obtain eigenvalues and associated eigenvector matrix . The square root of the inverse of can then be estimated as
(45.25)
and the log-likelihood Equation (45.20) is maximized at
(45.26)
The discussion thus far has ignored the presence of deterministic terms in the VAR specification. The inclusion of deterministics has important implications for the estimation and interpretation of VECMs, and there are different approaches to incorporating these terms.
Following Lütkepohl (2005), the classical approach to incorporating deterministic terms in VECMs is to let follow a basic VAR() as in Equation (45.1), and to work with the augmented process,
(45.27)
where denotes any -dimensional deterministic function of time, often a low-order polynomial in .
Substituting into the VECM Equation (45.4), we obtain:
(45.28)
For example, if is a constant function, , then for all , and we have
(45.29)
In this case, the constant function may either be viewed as an intercept inside the cointegrating relation, , or simply as an overall intercept in the VECM. Importantly, in the latter case, the overall is said to be restricted since it must satisfy the restriction imposed by the cointegrating relationship.
Likewise, if is a linear trend, , then for all , we have
(45.30)
In this case, the trend function may be included as a term in the cointegrating relation, along with the term appearing in the short-run dynamics, or as an overall intercept and trend in VECM (). Notably, while the overall trend coefficient is restricted by the cointegrating relationship, the constant is unrestricted as it contains free parameters unrelated to from the short-run dynamics.
Lütkepohl (2005) emphasizes the importance of the cointegrating restrictions in governing the dynamic behavior of the levels of , noting that their removal induces additional deterministics in the integrated VAR representation of the VECM. For example, if the restriction on in Equation (45.29) is removed, the corresponding integrated VAR specification will have a deterministic trend in the mean. Similarly, removing the restriction on in Equation (45.30) will generate a quadratic trend in the VAR.
We can make the separation between restricted and unrestricted deterministics concrete by re-parameterizing Equation (45.28) to provide a general framework for a VECM with deterministics:
(45.31)
where and are vector-valued functions denoting unrestricted and restricted deterministics, respectively, with corresponding coefficients and . and are assumed to be exclusive so that any deterministic function in is not included in , and vice versa. For the constant function above, is empty and . For the linear trend function , , and .
Lastly, note that while this discussion has focused on deterministic functions of time, the framework allows for the consideration of other types of exogenous variables which enter either the restricted cointegrating or the unrestricted transitory space.
An alternative treatment of deterministics follows the conventions outlined in Johansen (1995), Hendry and Juselius (2001), and Juselius (2006), which we will term the JHJ approach. The approach begins with the VECM specification:
(45.32)
By virtue of cointegration, both and are stationary around their expected values. Taking expectations of Equation (45.32) yields:
(45.33)
for
(45.34)
where is the lag operator.
Let and be the expected value paths of and . Then rewriting Equation (45.33) in terms of the deterministic component yields,
(45.35)
Johansen (1995) and Juselius (2006) show that and may be thought of as decompositions of into components in the orthogonal directions of and . Since is the weighting matrix for the expected congregating relation , are orthogonal weights for the expected common trends (transitory variables).
It follows that this expression additively decomposes the deterministic function into the space spanned by the transitory variables , and the space spanned by the cointegrating relations .
What distinguishes this decomposition from the classical approach is that each coefficient vector can itself be decomposed into the spaces spanned by and . As discussed in Johansen (1995) and Juselius (2006), this result follows from a family of identities similar to
(45.36)
Thus, each deterministic term can be decomposed into orthogonal components so that it appears simultaneously in the unrestricted (transitory) and restricted (cointegrated) spaces.
For example, when is a constant function, we have the decomposition,
(45.37)
where and . In other words, and the VECM in Equation (45.32) may be written as:
(45.38)
Similarly, when is a linear trend function, the following decompositions follow:
(45.39)
so that and . In this case the VECM in Equation (45.32) is given by
(45.40)
Estimation of VECMs with deterministics requires modification of the approach outlined in “Basic VECM Estimation”.
Deterministic specifications which derive from the classical approach in Equation (45.28) are accommodated by including the restricted deterministic regressors in the cointegrating space, and the unrestricted deterministics in the overall VECM. We modify Equation (45.18) to provide:
(45.41)
where
(45.42)
where and , and are the unrestricted and restricted deterministic components and coefficients, respectively.
When deterministics are incorporated using the JHJ convention, the estimator must allow for the possibility that the same deterministic term can appear both inside the cointegrating equation and outside it.
It is useful to divide the cointegrating regressors and coefficients into those present only inside the cointegrating equation ( and ), those present only outside the equation ( and ), and those that are both inside and outside the cointegrating relation (, , and ) so that we have and , with coefficients , and .
One estimation approach hinges on the ideas that the cointegrating (equilibrium) equation is stable around its mean of zero:
(45.43)
Given this requirement, estimation may be conducted in three steps:
Step 1: All dual deterministic regressors are first removed from inside the cointegrating relationship, but retained outside. Then , and are estimated using the classical approach outlined in Equation (45.26) and Equation (45.42) using deterministics and coefficients .
Step 2: Given the estimates and from Step 1, is estimated by choosing values of the coefficients so that the cointegrating equation has conditional mean zero:
(45.44)
Step 3: Using the estimates from Steps 1 and 2, the short-run coefficients are estimated using appropriately modified versions of the expressions in Equation (45.26) and Equation (45.42) with deterministics and coefficients .
While there is no single approach for estimating the coefficients in Step 2 above, a simple linear regression of on satisfies the desired condition. When the deterministic regressors are the usual constant and trend, this regression reduces to a familiar least squares detrending of the cointegrating relation. See also Proposition 7.5 in Lütkepohl (2005). This is the method employed by EViews.
For example, consider a model where the constant and trend terms appear both inside and outside the cointegrating equation:
(45.45)
Step 1 estimates the classical model,
(45.46)
to obtain estimates and , along with , , and for .
Step 2 uses the least squares regression,
(45.47)
to obtain estimates and .
Step 3 updates the estimates of , , and the using standard regression,
(45.48)
The final coefficient estimates are given by and from Step 1, and from Step 2, and from Step 3.
The empirical literature has centered around five scenarios involving deterministic terms:
Case 1: No deterministics, so that , in the classical framework, and in the JHJ approach.
Case 2: Restricted constant, so that and and in the classical formulation, and and under JHJ.
Here, the constant is restricted to the cointegrating space and does not appear in the transitory space. The cointegrating mean is non-zero and the cointegrating equation restriction ensures that no linear trends exist in the corresponding VAR.
Case 3: Unrestricted constant, so that , and in the classical approach, and and for JHJ.
In this case, the constant appears in the transitory space but does not appear in the cointegrating space. The model has no deterministics in the cointegrating space, and exhibits a linear trend in the VAR representation.
Case 3 (JHJ): Unrestricted constant in both the transitory and the cointegrating space so that and .
This JHJ model has a non-zero mean in the cointegrating relations, and has a linear trend in the corresponding VAR. Note that this case reduces to classical Case 3 when the restriction is imposed.
Case 4: Unrestricted constant and restricted trend so that , and , in the classical approach; and for under JHJ.
Here, a constant appears in the transitory space but does not appear in the cointegrating space, and the trend term appears only in the cointegrating space. This model has a linear trend in the cointegrating relations, and has a linear trend in the corresponding VAR representation.
Case 4 (JHJ): Unrestricted constant and restricted trend so that and in the JHJ framework.
The constant appears in both the transitory space and the cointegrating space, while the trend term appears only in the cointegrating space. The model has a non-zero mean and non-zero trend in the cointegrating relations, and has a linear trend in the corresponding VAR formulation. Note that this case reduces to classical Case 4 when the restriction is imposed.
Case 5: Unrestricted constant and trend, so that , and in the classical approach; , and under JHJ.
Here, the constant and trend appears in the transitory space. The model has a non-zero mean and non-zero trend in the cointegrating relations, and has a quadratic trend in the corresponding VAR.
Case 5 (JHJ): Unrestricted constant and trend, so that , and , .
In this case, the constant and trend appear in both the transitory and cointegrating spaces. The model has a non-zero mean and non-zero trend in the cointegrating relations, and has a quadratic trend in the corresponding VAR formulation. Note that this case reduces to classical Case 5 when the restrictions are imposed.
The endogenous variables in our VEC model are the variables whose dynamics and evolution are determined within the VEC system. Given the autoregressive nature of the model, these variables are necessarily correlated with the errors .
Accordingly, a particularly convenient (albeit slightly restrictive) definition of the exogenous variables in a VEC setting is any set of variables which are independent of the error process , and included in the VEC specification and estimated alongside their endogenous counterparts. Notice by this definition, deterministic regressors are examples of exogenous variables in VEC models.
The discussion on deterministics in Vector Error Correction Models (VECMs) is applicable to arbitrary exogenous regressors, not just those which are deterministic regressors involving explicit polynomials of time. Thus incorporation of exogenous variables requires no meaningful adjustment to the estimation procedures outlined in “Estimating VECM with Deterministics”.
More formally, let denote a set of exogenous variables, and for generality, suppose we wish to include an order q distributed lag of in the VECM.
Starting with the classical convention for deterministics in Equation (45.27), we specify a VAR(p) process where the endogenous variables are autoregressive of order p and whose difference specification includes exogenous variables that are distributed lag variables of order q. Then the exogenous component is assumed to be:
(45.49)
where are coefficient matrices associated with the lags of the exogenous variables.
Lütkepohl (2005) argues that the VEC representation of this model can assume two forms. In the first form, the endogenous variables are cointegrated among themselves, but not with the set of exogenous variables In this case, the VEC representation is given by:
(45.50)
In the second form the endogenous variables are not only cointegrated among themselves, but also with the exogenous variables . Here the VEC representation is:
(45.51)
Notice that both of these specifications are embedded in the general classical framework for deterministics described above ( “The Classical Approach”):
(45.52)
where in the first form, we have,
(45.53)
while in the second form, we have,
(45.54)
Similarly, it is possible to decompose each of the coefficient matrices in (18) into the spaces spanned by and as in “The Johansen, Hendry, and Juselius Approach”. This decomposition would produce a model in which exogenous regressors appear both among the long-run and short-run regressors.
While we see that exogenous regressors are conceptually analogous to deterministic regressors, caution must be exercised when augmenting VEC models with deterministic regressors. Notably, since the deterministic regressors enter into the differenced VEC models ( Equation (45.27) and Equation (45.27)), their inclusion will have implications for the behavior of the equivalent VAR level form that should be considered. These nuances are analogous to role of deterministics in the unit root literature where, for instance, a constant term in a random walk will generate a linear trend in the mean. While these considerations are also present for the deterministic trend regressors, the implications for trend regressors are more obvious as the inclusion of the trends is generally described in terms of the effects on both the levels and the differences.
