Object Reference : Object View and Procedure Reference : Vector
classify
Recode the vector into classes defined by a grid, specified limits, or quantiles.
vector_name.classify(options) spec @ outname [mapname]
You should follow the classify keyword with any desired options, a specification spec, the “@”-sign, the name to be given the output series, and optionally the name for a valmap object describing the classification.
The form for the specification spec will depend on which of the four supported methods for classification is employed (using the “method=” option).
• If the default “method=step” is employed, EViews will construct the classification using the set of intervals of size step from start through end. The spec specification is of the form
stepsize start end
where stepsize is a positive numeric value and start and end are numeric values. If start or end are explicitly set to NAs, EViews will use the corresponding minimum and maximum value of the data extended by 5% (e.g., 0.95*min or 1.05*max).
• If “method=bins”, EViews will construct the classification by dividing the range between start and end into a specified number of bins. The specification is of the form:
nbins start end
where nbins in the integer number of bins. Note that depending upon whether you have selected left or right-closed intervals (using the “rightclosed” option), observations with values equal to the start or end may fall out-of-range.
• Using “method=limits” specifies a classification using bins defined by a set of limit values. The spec is given by:
arg1 [arg2 arg3 ...]
where the arguments are limit values or EViews vector objects containing limit values. The first limit value defines the upper limit of the first interval, and the last limit value defines the lower limit of the last interval. Note that there must be at least one limit value and that the values need not be provided in ascending or descending order.
• If “method=quants” is given, EViews uses the specified number of quantiles for the data, specified as an integer value. The specification is:
nquants
where nquants is the integer for the number of quantiles. For deciles you should set nquants =10, for quartiles, nquants = 4.
method=arg (default = “step”)
Method for determining classification values: “step”– create a grid from start through end using the stepsize; “bins” – create bins by dividing the region from start to end into a specified number of bins; “quants” – create bins using the quantile values; “limits” - create bins using the specified limit points.
rightclosed
Bins formed using right-closed intervals. is defined to be in the bin from to if . The default is to use intervals closed on the left.
rangeerr
Generate error if data value is found outside of defined bins. The default is to classify out-of-range values as NAs.
q=arg (default=“r”)
Quantile calculation method. “b” (Blom), “r” (Rankit-Cleveland), “o” (Ordinary), “t” (Tukey), “v” (van der Waerden), “g” (Gumbel). Only relevant where “method=quants”.
encode =arg (default=“index”)
Encoding method for output series: “index” – encode as integers from 0 to where is the number of bins, where the 0 is reserved for NA encoding if “keepna” is specified; “left” – encode using the left-most value defining the bin; “right” – encode using the right-most value defining the bin; “mid” – encode using the midpoint of the bin.
keepna
Classify NA values as 0 (for “encode=index” only).
prompt
p
Print the results.
vec1.classify 100 200 @ vec1_ct
classifies the values of VEC1 into bins of width 100 starting at 200 and ending at the data maximum times 1.05. The classification results are saved in the vector VEC1_CT.
vec1.classify(encode=right) 100 200 1100 @ vec1_ct1
classifies VEC1 into bins of size 100, from 200 through 1100. The output vector VEC1_CT1 will contain classification values taken from the right endpoints of the classification intervals. Rows with out-of-range values will be assign an NA.
vec1.classify(method=bins, rightclosed, rangeerr) 9 200 1100 @ vec1_ct2
defines 9 equally sized bins, starting at 200 and ending at 1100, and classifies the data into the vector VEC1_CT2. The bins are closed on the right, and out-of-range values will generate an error.
vec1.classify(method=quants, q=g, keepna) 4 @ vec1_ct3
classifies the values of VEC1 into quartiles (using the Gumbel definition) in the vector VEC1_CT3. Rows with NA values in VEC1 will be encoded as 0 in the output vector.
See “Generate by Classification” for additional discussion.
