read |
t=dat, txt | ASCII (plain text) files. |
t=wk1, wk3 | Lotus spreadsheet files. |
t=xls | Excel spreadsheet files. |
na=text | Specify text for NAs. Default is “NA”. |
d=t | Treat tab as delimiter (note: you may specify multiple delimiter options). The default is “d=c” only. |
d=c | Treat comma as delimiter. |
d=s | Treat space as delimiter. |
d=a | Treat alpha numeric characters as delimiter. |
custom = symbol | Specify symbol/character to treat as delimiter. |
mult | Treat multiple delimiters as one. |
rect (default) / norect | [Treat / Do not treat] file layout as rectangular. |
skipcol = integer | Number of columns to skip. Must be used with the “rect” option. |
skiprow = integer | Number of rows to skip. Must be used with the “rect” option. |
comment= symbol | Specify character/symbol to treat as comment sign. Everything to the right of the comment sign is ignored. Must be used with the “rect” option. |
singlequote | Strings are in single quotes, not double quotes. |
dropstrings | Do not treat strings as NA; simply drop them. |
negparen | Treat numbers in parentheses as negative numbers. |
allowcomma | Allow commas in numbers (note that using commas as a delimiter takes precedence over this option). |
letter_number (default=“b2”) | Coordinate of the upper-left cell containing data. |
s=sheet_name | Sheet name for Excel 5–8 Workbooks. |
