Exporting from a Workfile
MicroTSP Files
You can read or write your workfile in a format that is compatible with MicroTSP. The Files of type and Save as type dropdown menus in the Open and SaveAs dialogs allow you to handle DOS and Macintosh MicroTSP files. Simply click on the dropdown menu and select either Old Dos Workfile or Old Mac Workfile, as appropriate. You should be aware, however, that if you choose to save a workfile in MicroTSP format, only basic series data will be saved—the remainder of the workfile contents will be discarded.
Foreign Formats
To save your series (and possibly value map data) into a foreign data source, first select , from the workfile menu to bring up the standard file dialog. Clicking on the dropdown menu brings up a list of the output file types that EViews currently supports.
The data export interface is available for a wide range of formats including Microsoft Access, Aremos TSD, Gauss Dataset, GiveWin/Pc-Give, Rats 4.x, Rats Portable, SAS program files, SAS Transport, native SPSS (using an SPSS Input/output .DLL already installed on your system), SPSS Portable, Stata, TSP Portable, Excel, raw ASCII or binary files, R, JSON, Tableau, or ODBC Databases (using an ODBC driver already installed on your system).
