family=arg (default=“normal”) | Distribution family: Normal (“normal”), Poisson (“poisson”), Binomial Count (“binomial”), Binomial Proportion (“binprop”), Negative Binomial (“negbin”), Gamma (“gamma”), Inverse Gaussian (“igauss”), Exponential Mean (“emean)”, Power Mean (“pmean”), Binomial Squared (“binsq”). The Binomial Count, Binomial Proportion, Negative Binomial, and Power Mean families all require specification of a distribution parameter: |
n=arg (default=1) | Number of trials for Binomial Count (“family=binomial”) or Binomial Proportions (“family=binprop”) families. |
fparam=arg | Family parameter value for Negative Binomial (“family=negbin”) and Power Mean (“family=pmean”) families. |
link=arg (default=“identity”) | Link function: Identity (“identity”), Log (“log”), Log Compliment (“logc”), Logit (“logit”), Probit (“probit”), Log-log (“loglog”), Complementary Log-log (“cloglog”), Reciprocal (“recip”), Power (“power”), Box-Cox (“boxcox”), Power Odds Ratio (“opow”), Box-Cox Odds Ratio (“obox”). The Power, Box-Cox, Power Odds Ratio, and Box-Cox Odds Ratio links all require specification of a link parameter specified using “lparam=”. |
lparam=arg | Link parameter for Power (“link=power”), Box-Cox (“link=boxcox”), Power Odds Ratio (“link=opow”) and Box-Cox Odds Ratio (“link=obox”) link functions. |
offset=arg | Offset terms. |
disp=arg | Dispersion estimator: Pearson statistic (“pearson”), deviance statistic (“deviance”), unit (“unit”), user-specified (“user”).The default is family specific: “unit” for Binomial Count, Binomial Proportion, Negative Binomial, and Poison, and “pearson” for all others. The “deviance” option is only offered for families in the exponential family of distributions (Normal, Poisson, Binomial Count, Binomial Proportion, Negative Binomial, Gamma, Inverse Gaussian). |
dispval=arg | User-dispersion value (if “disp=user”). |
fwgts=arg | Frequency weights. |
w=arg | Weight series or expression. |
wtype=arg (default=“istdev”) | Weight specification type: inverse standard deviation (“istdev”), inverse variance (“ivar”), standard deviation (“stdev”), variance (“var”). |
wscale=arg | Weight scaling: EViews default (“eviews”), average (“avg”), none (“none”). The default setting depends upon the weight type: “eviews” if “wtype=istdev”, “avg” for all others. |
optmethod = arg | Optimization method: “bfgs” (BFGS); “newton” (Newton-Raphson), “opg” or “bhhh” (OPG or BHHH), “fisher” (IRLS – Fisher Scoring), “legacy” (EViews legacy). Newton-Raphson is the default method. |
optstep = arg | Step method: “marquardt” (Marquardt); “dogleg” (Dogleg); “linesearch” (Line search). Marquardt is the default method. |
estmeth=arg (default=”marquardt”) | Legacy estimation algorithm: Quadratic Hill Climbing (“marquardt”), Newton-Raphson (“newton”), IRLS - Fisher Scoring (“irls”), BHHH (“bhhh”). (Applicable when “optmethod=legacy”.) |
m=integer | Set maximum number of iterations. |
c=scalar | Set convergence criterion. The criterion is based upon the maximum of the percentage changes in the scaled coefficients. The criterion will be set to the nearest value between 1e-24 and 0.2. |
s | Use the current coefficient values in estimator coefficient vector as starting values (see also
param). |
s=number | Specify a number between zero and one to determine starting values as a fraction of EViews default values (out of range values are set to “s=1”). |
showopts / ‑showopts | [Do / do not] display the starting coefficient values and estimation options in the estimation output. |
preiter=arg (default=0) | Number of IRLS pre-iterations to refine starting values (only available for non-IRLS estimation). |
cov=arg | Covariance method: “ordinary” (default method based on inverse of the estimated information matrix), “huber” or “white” (Huber-White sandwich method), “glm” (GLM method). |
covinfo = arg | Information matrix method: “opg” (OPG); “hessian” (observed Hessian), “fisher” (expected Hessian). (Applicable when “optmethod=” not equal to “legacy”. |
nodf | Do not degree-of-freedom correct the coefficient covariance estimate. |
covlag=arg (default=1) | Whitening lag specification: integer (user-specified lag value), “a” (automatic selection). Applicable where “cov=hac”. |
covinfosel=arg (default=”aic”) | Information criterion for automatic selection: “aic” (Akaike), “sic” (Schwarz), “hqc” (Hannan-Quinn) (if “lag=a”). For settings where “cov=hac, covlag=a”. |
covmaxlag=integer | Maximum lag-length for automatic selection (optional) (if “lag=a”). The default is an observation-based maximum of .For settings where “cov=hac, covlag=a”. |
covkern=arg (default=“bart”) | Kernel shape: “none” (no kernel), “bart” (Bartlett, default), “bohman” (Bohman), “daniell” (Daniel), “parzen” (Parzen), “parzriesz” (Parzen-Riesz), “parzgeo” (Parzen-Geometric), “parzcauchy” (Parzen-Cauchy), “quadspec” (Quadratic Spectral), “trunc” (Truncated), “thamm” (Tukey-Hamming), “thann” (Tukey-Hanning), “tparz” (Tukey-Parzen). For settings where “cov=hac”. |
covbw=arg (default=“fixednw”) | Kernel Bandwidth: “fixednw” (Newey-West fixed), “andrews” (Andrews automatic), “neweywest” (Newey-West automatic), number (User-specified bandwidth). For settings where “cov=hac” and “covkern=” is specified. |
covnwlag=integer | Newey-West lag-selection parameter for use in nonparametric kernel bandwidth selection (if “covbw=neweywest”). For settings where “cov=hac” and “covkern=” is specified. |
covbwoffset=number | Apply offset to automatically selected bandwidth. For settings where “cov=hac”, “covkern=” is specified, and “covbw=” is not user-specified. |
covbwint | Use integer portion of kernel bandwidth. For settings where “cov=hac” and “covkern=” is specified. |
coef=arg | Specify the name of the coefficient vector (if specified by list); the default behavior is to use the “C” coefficient vector. |
p | Print results. |
