Make a model from a likelihood object.
logl_name.makemodel(name) assign_statement
If you provide a name for the model in parentheses after the keyword, EViews will create the named model in the workfile. If you do not provide a name, EViews will open an untitled model window if the command is executed from the command line.
ll3.makemodel(logmod) @prefix s_
makes a model named LOGMOD from the estimated logl object. LOGMOD includes an assignment statement “ASSIGN @PREFIX S_”. Use the command “show logmod” or “logmod.spec” to open the LOGMOD window.
See
“Models” for a discussion of specifying and solving models in EViews.
