-vectors
that may depend on a
‑vector of parameters
, and let
where
is the true value of
. We are interested in estimating the LRCOV matrix
,![]() | (60.32) |
![]() | (60.33) |
at lag
. When
is second-order stationary,
equals
times the spectral density matrix of
evaluated at frequency zero (Hansen 1982, Andrews 1991, Hamilton 1994).
are two measures of the one-sided LRCOV matrix:![]() | (60.34) |
, which we term the strict one-sided LRCOV, is the sum of the lag covariances, while the
also includes the contemporaneous covariance
. The two-sided LRCOV matrix
is related to the one-sided matrices through
and
, since results are generally applicable to all three measures; exception will be made for specific issues that require additional comment.
and the corresponding
to form a consistent estimate of
are often referred to as heteroskedasticity and autocorrelation consistent (HAC) covariance matrix estimators.
by taking a weighted sum of the sample autocovariances of the observed data.
is obtained by “recoloring” the prewhitened LRCOV to undo the effects of the whitening transformation.![]() | (60.35) |
are given by![]() | (60.36) |
is a symmetric kernel (or lag window) function that, among other conditions, is continous at the origin and satisfies
for all
with
, and
is a bandwidth parameter. The leading
term is an optional correction for degrees-of-freedom associated with the estimation of the
parameters in
.Truncated uniform | ![]() |
Bartlett | ![]() |
Bohman | ![]() |
Daniell | ![]() |
Parzen | ![]() |
Parzen-Riesz | ![]() |
Parzen-Geometric | ![]() |
Parzen-Cauchy | ![]() |
Quadratic Spectral | ![]() |
Tukey-Hamming | ![]() |
Tukey-Hanning | ![]() |
Tukey-Parzen | ![]() |
for
for all kernels with the exception of the Daniell and the Quadratic Spectral. The Daniell kernel is presented in truncated form in Neave (1972), but EViews uses the more common untruncated form. The Bartlett kernel is sometimes referred to as the Fejer kernel (Neave 1972).
operates in concert with the kernel function to determine the weights for the various sample autocovariances in
Equation (60.35). While some authors restrict the bandwidth values to integers, we follow Andrews (1991) who argues in favor of allowing real valued bandwidths.
. Under general conditions (Andrews 1991), consistency of the kernel estimator requires that
is chosen so that
and
as
. Alternately, Kiefer and Vogelsang (2002) propose setting
in a testing context.
for
so that the bandwidth acts indirectly as a lag truncation parameter. Relating
to the corresponding integer lag number of included lags
requires, however, examining the properties of the kernel at the endpoints
. For kernel functions where
(e.g., Truncated, Parzen-Geometric, Tukey-Hanning),
is simply a real-valued truncation lag, with at most
autocovariances having non-zero weight. Alternately, for kernel functions where
(e.g., Bartlett, Bohman, Parzen), the relationship is slightly more complex, with
autocovariances entering the estimator with non-zero weights.
weighted autocovariance lags requires setting
. In contrast, Hansen’s (1982) or White’s (1984) estimators, which sum the first
unweighted autocovariances, should be implemented using the Truncated kernel with
.![]() | (60.37) |
is a constant, and
is a parameter that depends on the kernel function that you select (Parzen 1958, Andrews 1991). For the Bartlett and Parzen-Geometric kernels
should grow (at most) at the rate
. The Truncated kernel does not have an theoretical optimal rate, but Andrews (1991) reports Monte Carlo simulations that suggest that
works well. The remaining EViews supported kernels have
so their optimal bandwidths grow at rate
(though we point out that Daniell kernel does not satisfy the conditions for the optimal bandwidth theorems).
does not tell us the optimal bandwidth for a given sample size, since the constant
remains unspecified.
. We may term these techniques automatic bandwidth selection methods, since they involve estimating the optimal bandwidth from the data, rather than specifying a value a priori. Both the Andrews and Newey-West estimators for
may be written as:![]() | (60.38) |
and the constant
depend on properties of the selected kernel and
is an estimator of
, a measure of the smoothness of the spectral density at frequency zero that depends on the autocovariances
. Substituting into
Equation (60.37), the resulting plug-in estimator for the optimal automatic bandwidth is given by:![]() | (60.39) |
that one uses depends on properties of the selected kernel function. The Bartlett and Parzen-Geometric kernels should use
since they have
should be used for the other EViews supported kernels which have
. The Truncated kernel does not have a theoretically proscribed choice, but Andrews recommends using
. The Daniell kernel has
, though we remind you that it does not satisfy the conditions for Andrews’s theorems.
“Kernel Function Properties” summarizes the values of
and
for the various kernel functions.
that requires forming preliminary estimates of
and the smoothness of
. Andrews and Newey-West offer alternative methods for forming these estimates.
parametrically: fitting a simple parametric time series model to the original data, then deriving the autocovariances
and corresponding
implied by the estimated model.
formulae for several parametric models, noting that the choice between specifications depends on a tradeoff between simplicity and parsimony on one hand and flexibility on the other. EViews employs the parsimonius approach used by Andrews in his Monte Carlo simulations, estimating
-univariate AR(1) models (one for each element of
), then combining the estimated coefficients into an estimator for
.![]() | (60.40) |
are parametric estimators of the smoothness of the spectral density for the
-th variable (Parzen’s (1957)
‑th generalized spectral derivatives) at frequency zero. Estimators for
are given by:![]() | (60.41) |
and
, where
are the estimated autocovariances at lag
implied by the univariate AR(1) specification for the
‑th variable.
and standard errors
into the theoretical expressions for
, we have:![]() | (60.42) |
depend on the weighting vector
which governs how we combine the individual
into a single measure of relative smoothness. Andrews suggests using either
for all
or
for all but the instrument corresponding to the intercept in regression settings. EViews adopts the first suggestion, setting
for all
. In contrast to Andrews who computes parametric estimates of the individual
, Newey-West uses a Truncated kernel estimator to estimate the
corresponding to aggregated data.![]() | (60.43) |
may either be viewed as the sample autocovariance of a weighted linear combination of the data using weights
, or as a weighted combination of the sample autocovariances.
to compute nonparametric truncated kernel estimators of the Parzen measures of smoothness:![]() | (60.44) |
. These nonparametric estimators are weighted sums of the scalar autocovariances
obtained above for
from
to
, where
, which Newey and West term the lag selection parameter, may be viewed as the bandwidth of a kernel estimator for
may then be written as:![]() | (60.45) |
. This expression may be inserted into
Equation (60.39) to obtain the expression for the plug-in optimal bandwidth estimator.
-dimensions of the original data into a scalar measure
. Andrews computes parametric estimates of the generalized derivatives for the
individual elements, then aggregates the estimates into a single measure. In contrast, Newey and West aggregate early, forming linear combinations of the autocovariance matrices, then use the scalar results to compute nonparametric estimators of the Parzen smoothness measures.
, the lag-selection parameter, which governs how many autocovariances to use in forming the nonparametric estimates of
. Newey and West show that
should increase at (less than) a rate that depends on the properties of the kernel. For the Bartlett and the Parzen-Geometric kernels, the rate is
. For the Quadratic Spectral kernel, the rate is
. For the remaining kernels, the rate is
(with the exception of the Truncated and the Daniell kernels, for which the Newey-West theorems do not apply).
. Newey-West (1987) leave open the choice of
, but follow Andrew’s (1991) suggestion of
for all but the intercept in their Monte Carlo simulations. EViews differs from this choice slightly, setting
for all
, computing the contemporaneous covariance of the filtered data, then using the estimates from the VAR model to obtain the implied autocovariances and corresponding LRCOV matrix of the original data.
) model to the
. Let
be the
matrix of estimated
-th order AR coefficients,
. Then we may define the innovation (filtered) data and estimated innovation covariance matrix as:![]() | (60.46) |
![]() | (60.47) |
and the VAR coefficients
, we can compute the implied theoretical autocovariances
of
. Summing the autocovariances yields a parametric estimator for
, given by:![]() | (60.48) |
![]() | (60.49) |
, the order of the VAR. Den Haan and Levin use model selection criteria (AIC or BIC-Schwarz) using a maximum lag of
to determine the lag order, and provide simulations of the performance of estimator using data-dependent lag order.
and
do not have simple expressions in terms of
and
. We can, however, obtain insight into the construction of the one-sided VARHAC LRCOVs by examining results for the VAR(1) case. Given estimation of a VAR(1) specification, the estimators for the one-sided long-run variances may be written as:![]() | (60.50) |
, as well as an estimate of
, the contemporaneous covariance matrix of
so that the estimates of
and
employ a mix of parametric and non-parametric autocovariance estimates. Alternately, in keeping with the spirit of the parametric methodology, EViews constructs a parametric estimator
using the estimated VAR(1) coefficients
and
) model to the
and obtain the whitened data (residuals):![]() | (60.51) |
values that are closer to white-noise. (In addition, Andrews and Monahan adjust their VAR(1) estimates to avoid singularity when the VAR is near unstable, but EViews does not perform this eigenvalue adjustment.)![]() | (60.52) |
are given by![]() | (60.53) |
![]() | (60.54) |
are white noise so that the LRCOV may be estimated using the contemporaneous variance matrix
, while the prewhitening kernel estimator in
Equation (60.52) allows for residual heteroskedasticity and serial dependence through its use of the HAC estimator
. Accordingly, it may be useful to view the VARHAC procedure as a special case of the prewhitened kernel with
and
for
(Park and Ogaki, 1991). As in the VARHAC setting, the expressions for one-sided LRCOVs are quite involved but the VAR(1) specification may be used to provide insight. Suppose that the VARHAC estimators of the one-sided LRCOV matrices defined in
Equation (60.50) are given by
and
, and let
be the strict one-sided kernel estimator computed using the prewhitened data:![]() | (60.55) |
![]() | (60.56) |
