solveopt |
s=arg (default=“d”) | Solution type: “d” (deterministic), “m” (stochastic – collect means only), “s” (stochastic – collect means and s.d.), “b” (stochastic – collect means and confidence bounds), “a” (stochastic – collect all; means, s.d. and confidence bounds). |
d=arg (default=“d”) | Model solution dynamics: “d” (dynamic solution), “s” (static solution), “f” (fitted values – single equation solution). |
struct=t | Ignore ARMA terms and use only the structural part of the equations when solving the model. |
m=integer (default=5000) | Maximum number of iterations for solution (maximum 100,000). |
c=number (default=1e-8) | Convergence criterion. Based upon the maximum change in any of the endogenous variables in the model. You may set a number between 1e-15 and 0.01. |
a=arg (default=“f”) | Alternate scenario solution: “t” (true - solve both active and alternate scenario and collect deviations for stochastic), “f” (false - solve only the active scenario). |
o=arg (default=“g”) | Solution method: “g” (Gauss-Seidel), “n” (Newton), “b” (Broyden), “w” (E-Newton), “q” (E-QNewton). |
i=arg (default=“a”) | Set initial (starting) solution values: “a” (actuals), “p” (values in period prior to start of solution period). |
n=arg (default=“t”) | NA behavior: “t” (true - stop on “NA” values), “f” (false - do not stop when encountering “NA” values). Only applies to deterministic solution; EViews will always stop on “NA” values in stochastic solution. |
e=arg (default=“t”) | Excluded variables initialized from actuals: “t” (true), “f” (false). |
t=arg (default=“u”) | Terminal condition for forward solution: “u” (user supplied - actuals), “l” (constant level), “d” (constant difference), “g” (constant growth rate). |
w=arg | Solve direction: “t” (two-directional), “f” (forwards only). |
g=arg (default==7) | Number of digits to round solution: an integer value (number of digits), “n” (do not roundoff). |
z=arg (default==1e-7) | Zero value: a positive number below which the solution (absolute value) is set to zero, “n” (do not set to zero). |
f=arg (default==”t”) | Order simultaneous blocks for minimum feedback: “t” (true), “f” (false). |
v=arg (default==“f”) | Display verbose diagnostic messages: “t” (true), “f” (false). |
j=arg (default==“a”) | Use analytic or numeric Jacobians: “a” (analytic), “n” (numeric only). |
