Model
Set of simultaneous equations used for forecasting and simulation.
Model Declaration
model declare model object.
Declare an object by entering the keyword model, followed by a name:
model mymod
declares an empty model named MYMOD. To fill MYMOD, open the model and edit the specification view, or use the append view. Note that models are not used for estimation of unknown parameters.
See also the section on model keywords in
“Text View”.
Model Views
block display model block structure.
boundscheck show a display of any series that have crossed their set boundaries during a solve.
compare show the differences between scenarios for the specified series.
display display table, graph, or spool in object window.
eqs view of model organized by equation.
digraph display the model dependency graph.
label view or set label information for the model.
msg display model solution messages.
printview show enhanced display of the mode specification.
scenlist display list description of the model scenarios.
text show text showing equations in the model.
trace view of trace output from model solution.
vars view of model organized by variable.
Model Procs
adjust prepare a variable for editing in the current scenario and/or update its values using an array expression.
addover set the active scenario add factor overrides.
append append a line of text to a model.
control solve for values of control variables so that targets match trajectories.
copy creates a copy of the model.
drop drop equations for one or more endogenous variables in the model .
droplink drop linked objects from the model.
exclude specifies (or merges) excluded series to the active scenario.
fliptype respecify model by selecting a new set of endogenous variables.
innov solve options for stochastic simulation.
makegraph make graph object showing model series.
makegroup make group out of model series and display dated data table.
merge merge objects into the model.
olepush push updates to OLE linked objects in open applications.
override specifies (or merges) override series to the active scenario.
reinclude removes one or more variables from the excluded variable list.
replace replace the text specification for an endogenous variable in the model with a new specification.
replacelink replace a linked object with a different linked object.
replacevar replace all instances of a variable in the text specification of a model with a different variable.
revert revert one or more overridden variables in the active scenario back to baseline values.
scenario set the active, alternate, or comparison scenario.
setattr set the value of an object attribute.
setbounds set upper and lower boundaries for endogenous variables during model solution.
settrace specify the endogenous variables to be traced when solving the model.
spec display the text specification view.
trace specify endogenous variables to trace.
track specify endogenous variables to track.
unlink break links in specification.
update update model specification.
Model Data Members
Scalar values
@bounds integer containing the number of variables that crossed their boundaries during the previous solve.
String values
@attr("arg" string containing the value of the arg attribute, where the argument is specified as a quoted string.
@description string containing the Model object’s description (if available).
@detailedtype string with the object type: “MODEL”.
@displayname string containing the Model object’s display name. If the Model has no display name set, the name is returned.
@droppedaf string containing a space delimited list of the add factor series dropped or converted to exogenous series, if any, as part of the last successful fliptype procedure. The order of series in this list matches the order of series in the related data member @dropedafdep.
@droppedafdep string containing a space delimited list of dependent series that had add factors dropped or converted to exogenous series, if any, as part of the last successful fliptype procedure. The order of series in this list matches the order of series in the related data member @dropedaf.
@name string containing the Model object’s name.
@remarks string containing the Model object’s remarks (if available).
@scenarios string containing a list of scenarios in the Model.
@type string with the object type: “MODEL”.
@updatetime string representation of the time and date at which the Model was last updated.
String values for Model variables
@addfactors[(“scenario”)] or @aflist[(“scenario”)] string containing a space delimited list of the model’s addfactor variables in the specified scenario (default is Actuals).
@depends("variable") string containing the variables that “variable” depends on.
@endoglist[(“scenario”)] string containing a space delimited list of the model’s endogenous variables in the specified scenario (default is Actuals).
@excludelist[(“scenario”)] string containing a space delimited list of the model’s excluded variables in the specified scenario (default is Actuals).
@exoglist[(“scenario”)] string containing a space delimited list of the model’s exogenous variables in the specified scenario (default is Actuals).
@identity string containing a space delimited list of the model’s endogenous variables determined by identities.
@overridelist[(“scenario”)] or @olist[(“scenario”)] string containing a space delimited list of the model’s variables set as overrides in the specified scenario (default is Actuals).
@linklist string containing space delimited list of all linked objects in the model
@spec(“variable”) string containing the estimation object name or text specification of the equation determining the specified endogenous variable, or an empty string if “variable” is an invalid name.
@stochastic string containing a space delimited list of stochastic endogenous variables.
@upends("variable") string containing the variables that depend on “variable”.
@varlist[(“scenario”)] string containing a space delimited list of all the model’s variables for the specified scenario (default is Actuals).
In addition to a scenario name, you may specify “@active” (in quotes) to specify the current active scenario or “@alternate” to specify the current alternative scenario.
Model Examples
The commands:
model mod1
mod1.append y=324.35+x
mod1.append x=-234+7.3*z
mod1.solve(m=100,c=.008)
create, specify, and solve the model MOD1.
The command:
mod1(g).makegraph gr1 x y z
plots the endogenous series X, Y, and Z, in the active scenario for model MOD1.
