Command Reference : Programming Language Summary : Dialog Display Functions
Programming Language Entries
call
else
endif
endsub
exitloop
for
if
include
poff
pon
return
sleep
step
stop
subroutine
then
to
Used in a FOR loop:
Used as a Lag specifier:
wend
while
@uidialog Display a dialog with multiple controls.
@uiedit Display a dialog with an edit control.
@uifiledlg Display a file open and save dialog.
@uilist Display a dialog with a listbox control.
@uimlist Display a dialog with a multiple-select listbox control.
@uiprompt Display a prompt dialog.
@uiradio Display a dialog with radio buttons.
call
Call a subroutine within a program.
The call statement is used to call a subroutine within a program.
See “Calling Subroutines”. See also subroutine, endsub.
else
ELSE clause of IF statement in a program.
Starts a sequence of commands to be executed when the IF condition is false. The else keyword must be terminated with an endif.
if [condition] then
[commands to be executed if condition is true]
else
[commands to be executed if condition is false]
endif
See “IF Statements”. See also, if, endif, then.
endif
End of IF statement. Marks the end of an IF, or an IF-ELSE statement.
if [condition] then
[commands if condition true]
endif
See “IF Statements”. See also, if, else, then.
endsub
Mark the end of a subroutine.
subroutine name(arguments)
commands
endsub
See “Defining Subroutines”. See also, subroutine, return.
exitloop
Exit from current loop in programs.
exitloop causes the program to break out of the current FOR or WHILE loop.
Command: exitloop
for !i=1 to 107
if !i>6 then exitloop
See “The FOR Loop”. See also, stop, return, for, next, step.
for
FOR loop in a program.
The for statement is the beginning of a FOR...NEXT loop in a program.
for counter=start to end [step stepsize]
[commands]
See “The FOR Loop”. See also, exitloop, next, step.
if
The if statement marks the beginning of a condition and commands to be executed if the statement is true. The statement must be terminated with the beginning of an ELSE clause, or an endif.
if [condition] then
endif
See “IF Statements”. See also else, endif, then.
include
Include another file in a program.
The include statement is used to include the contents of another file in a program file.
If an include file is specified without an absolute path, the base location will be taken from the location of the program file, not from the default directory.
include filename
See “Multiple Program Files”. See also call.
End of FOR loop. next marks the end of a FOR loop in a program.
for [conditions of the FOR loop]
[commands]
See “The FOR Loop”. See also, exitloop, for, step.
poff
Turn off automatic printing in programs.
poff turns off automatic printing of all output. In programs, poff is used in conjunction with pon to control automatic printing; these commands have no effect in interactive use.
Command: poff
See “Print Setup” for a discussion of printer control.
See also pon.
pon
Turn on automatic printing in programs.
pon instructs EViews to send all statistical and data display output to the printer (or the redirected printer destination; see output). It is equivalent to including the “p” option in all commands that generate output. pon and poff only work in programs; they have no effect in interactive use.
Command: pon
See also poff.
return
Exit subroutine.
The return statement forces an exit from a subroutine within a program. A common use of return is to exit from the subroutine if an unanticipated error has occurred.
if [condition] then
return
endif
See “Subroutines”. See also exitloop, stop.
sleep
Pause program execution.
sleep n
pauses a program by n milliseconds (default is 5000).
Example
sleep 1000
step
Step size of a FOR loop.
for !i=a to b step n
[commands]
step may be used in a FOR loop to specify the size of the step in the looping variable. If no step is provided, for assumes a step of “+1”.
If a given step exceeds the end value b in the FOR loop specification, the contents of the loop will not be executed.
for !j=5 to 1 step -1
series x = nrnd*!j
repeatedly executes the commands in the loop with the control variable !J set to “5”, “4”, “3”, “2”, “1”.
for !j=0 to 10 step 3
series z = z/!j
Loops the commands with the control variable !J set to “0”, “3”, “6”, and “9”.
You should take care when using non-integer values for the stepsize since round-off error may yield unanticipated results. For example:
for !j=0 to 1 step .01
series w = !j
may stop before executing the loop for the value !J=1 due to round-off error.
See “The FOR Loop”. See also exitloop, for, next.
stop
Break out of program.
The stop command halts execution of a program. It has the same effect as hitting the F1 (break) key.
Command: stop
See also, exitloop, return.
subroutine
Declare a subroutine within a program.
The subroutine statement marks the start of a subroutine.
[commands]
endsub
See “Subroutines”. See also endsub.
then
Part of IF statement.
then marks the beginning of commands to be executed if the condition given in the IF statement is satisfied.
if [condition] then
endif
See “IF Statements”. See also, else, endif, if.
to
Expression || Program Statements
Upper limit of for loop OR lag range specifier.
to is required in the specification of a FOR loop to specify the upper limit of the control variable; see “The FOR Loop”.
When used as a lag specifier, to may be used to specify a range of lags to be used in estimation.
Used in a FOR loop:
for !i=n to m
[commands]
series_name(n to m)
ls cs c gdp(0 to -12)
Runs an OLS regression of CS on a constant, and the variables GDP, GDP(–1), GDP(–2), …, GDP(–11), GDP(–12).
See “The FOR Loop”. See also, exitloop, for, next.
wend
End of WHILE clause.
wend marks the end of a set of program commands that are executed under the control of a WHILE statement.
while [condition]
[commands while condition true]
wend
See “The WHILE Loop”. See also while.
while
Conditional control statement. The while statement marks the beginning of a WHILE loop.
The commands between the while keyword and the wend keyword will be executed repeatedly until the condition in the while statement is false.
while [condition]
wend
See “The WHILE Loop”. See also wend.
