Clear restriction text from a VAR object.
var_name.cleartext(arg)
You must specify the text type you wish to clear using one of the following arguments:
svar  | Clear text of identifying restrictions for a structural VAR.  |
coint  | Clear text of restrictions on the cointegration relations and/or adjustment coefficients.  |
var1.cleartext(svar)
var1.append(svar) @lr2(@u1) = 0
The first line clears the structural VAR identifying restrictions in VAR1. The next line specifies a new long-run restriction for a structural factorization.
