decomp |
over which to compute the variance decompositions.g | Display combined graphs, with the decompositions for each variable shown in a graph. |
m | Display multiple graphs, with each response-shock pair shown in a separate graph. |
t (default) | Show numerical results in table. |
imp=arg (default=“chol”) | Type of factorization for the decomposition: “chol” (Cholesky with d.f. correction), “mlechol” (Cholesky without d.f. correction), “struct” (structural). The structural factorization is based on the estimated structural VAR. To use this option, you must first estimate the structural decomposition; see
Var::svar. The option “imp=mlechol” is provided for backward compatibility with EViews 3.x and earlier. |
se=mcarlo | Monte Carlo standard errors. You must specify the number of replications with the “rep=” option. Currently available only when you have specified the Cholesky factorization (using the “imp=chol” option). |
rep=integer | Number of Monte Carlo replications to be used in computing the standard errors. Must be used with the “se=mcarlo” option. |
cilevels=arg (default = “0.95”) | Confidence interval coverage: space limited list of numbers between 0 and 1. |
uselines | Use lines instead of shading for confidence intervals. |
matbys=name | Save responses by shocks (impulses) in named matrix. The first column is the response of the first variable to the first shock, the second column is the response of the second variable to the first shock, and so on. |
matbyr=name | Save responses by response series in named matrix. The first column is the response of the first variable to the first shock, the second column is the response of the first variable to the second shock, and so on. |
p | Print results. |
