white |
c | Include all possible nonredundant cross-product terms in the test regression. |
name=arg | Save test statistics in named matrix object. See below for a description of the statistics stored in the matrix. |
p | Print the test results. |
matrix, where
is the number of unique residual cross-product terms. For a VAR with
endogenous variables,
. The first
rows contain statistics for each individual test equation, where the first column is the regression R-squared, the second column is the F-statistic, the third column is the p-value of F-statistic, the 4th column is the
statistic, and the fifth column is the p-value of the
statistic.
-st row, while the
degrees of freedom is stored in the fifth column of the
-st row.
-st row and first column contains the joint (system) LM chi-square statistic and the second column contains the degrees of freedom of this
statistic.
